Its strange if nano seal = jetseal. Because Nano seal is mutch harder to remove! Jetseal is like removing a wax!
Very hard to remove 100 %. The manufacturer says that you can use QD or water to help removing it. Even, you could use Nano Shine Glaze over the dried Nano Seal and remove both products at the same time.
Haha that wouldn't be too good... If Nano Seal was easy to remove then I would really like it since u can buff off after 20 minutes and top it with whatever you want. Maybe I should leave it on longer...
That's odd as I have used Nano Seal probably about 12 times and have never ever had it be difficult to remove. It has always come off as easy as any other sealant I have used. I always leave it on for about an hour and then wipe off.
I have used XMT 360, Duragloss 501, Pinnacle Paintwork Cleansing Lotion, Optimum Poli-Seal, and even used Menzerna Finishing Glaze once under Nano Seal.
Hmm I've never tried to top it over something...I should try it after prepping with wolfgang paintwork enhancer
I just meant that people seem to rave about SC glass cleaner and it seems so special to some but no one has mentioned someone like CG's as being special. I do know that SC does not contain alcohol like Stoners does and supposedly all surfectants yet that is what supposedly causes streaking.
I cleansed some panels of my car and applied Nano Seal, waited 20 min and applied Nano Shine over Nano Seal, waited until it dried and then removed with Speed Demon. Much easy and great results.
I did the same but with Hot Rod Detailer . Sadly, the Nano Seal didn't last for me, but I probably didn't apply it correctly.
Hopefully CG's don't make them I find the surf city like ok for the average joe motorist but the range lacks serious polishes and anyone who still makes and sells dressings for trim is definately behind the times Trim can now be polished just like paint but with specialist non abrasive products and the result is permanent
