Pressure washer's???? Which one
Discussion in 'Car Detailing Product Discussion' started by LAV86, Dec 28, 2010.
  1. LAV86
    LAV86 Two Bucket System Washer
    IM IN THE MARKET FOR A PRESSURE WASHER BUT HARD TO DECIDE WHICH ONE TO BUY..IM LOOKING AT THE Cam Spray Prosumer 1450 PSI (Electric-Cold Water) Pressure Washer AND THE Kranzle Prosumer 1600 PSI (Electric-Cold) Pressure Washer w/Kranzle Pump..ANY INFO WILL BE GREAT ..THANKS
  2. detailersdomain
    do you have a 15 amp or 20 amp circuit?
  3. LAV86
    20 amp
  4. detailersdomain
    do you need a reel or the machine on a cart?
    if those don't matter pick up the cam spray.
  5. kdude
    kdude Jedi Nuba
    Not to take anything away from this thread how about a pressure washer that can use hot water ....
  6. 911Fanatic
    You should be able to run warm water through pretty much any pressure water but "hot" water will require a specialized unit. If you contact the manufacturer you should be able to find out what the maximum temp you can run through it without damaging anything.
  7. billyblooshoes
    this. my new briggs and stratton unit is technically a "cold water" pressure washer, but can handle water up to 100 degrees, which is plenty hot for all my "hot water pressure washer" needs.
  8. supercharged
    I'm running Cam Spray through 15A circuit without any issues....I highly recommend cam spray. It's a real hummer!
  9. LAV86
    Hey Phil do you have the cam spray and foam canon in stock?
  10. Danny
    Danny Nuba Guru
  11. rwisejr
    rwisejr DB Forum Supporter
    The Camspray unit is such a well built unit. I brought one a couple of years ago and it perfoms flawlessly. This equals money well spent.
