Paint Cleaner: Nuba & Sealant Friendly
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by agpatel, Oct 18, 2009.
  1. agpatel
    Looking around I do not see many paint cleaners/pre-wax cleaners that are both nuba and sealant friendly. What are some good cleaners that are friendly for both? i.e. pretty much leaves nothing behind but just does some cleaning. I know IPA is what many of you guys will say but looking at other alternatives, I currently have Griots Garage Paint Prep but it needs 5 min dwell time and just a mess sometimes to use. Looking at other options.
  2. kaiten408
    kaiten408 Jedi Nuba
    What about CG CWC? If you use it strong enough that will clean the paint and leave it LSP ready
  3. agpatel
    Have TC Citrus wash for that, but just looking at something were I do not have to was the whole car. But that is not out of the question.
  4. kaiten408
    kaiten408 Jedi Nuba
    That TC Citrus wash is pretty good, I picked up a gallon of it and love it.
  5. 911Fanatic
    Try Werkstat Prime. In the original version its good for either. :)
  6. agpatel
    :doh: How did I forget about that one! Thanks Ken!
  7. kc1337
    kc1337 Obsessive Detailer
    Should I still use Werkstat Prime on a surface already prepped by IPA?
  8. agpatel
    Prime is a cleaner and lays down a base of protection, sealant. So if you just want to clean the surface for wax then you only need to use one, no need for both. Prime will though give you a good base for another sealant or a nuba wax that is durable. So if you go with Prime you dont need to IPA.
  9. kc1337
    My current procedure is to wash, clay, IPA, Werkstat Prime, Sealant, Wax
  10. agpatel
    You could just do wash, clay, prime, sealant, wax. The IPA is kind of overkill as prime will clean the paint just fine.
  11. 911Fanatic
    +1. Only IPA if you are polishing to remove all polishing oils so no hologramming etc is hiding. The Prime is all you need after claying before LSP application. :)
  12. RNickolas
    RNickolas Obsessive Detailer
    cg ezcreme with acryllic glaze i believe has cleaners and can be topped with sealant or nuba...
  13. ahwil_lim
    ahwil_lim Wax on..Wax off
    how abt dodojuice prime lime?
  14. kustomizingkid
    kustomizingkid Nuba Guru
    What about Lusso Revializing creme?
  15. agpatel
    I think both have oils in it which are not good for sealants to be applied after using them. But, both are good pre-wax cleaners that clean the surfaces of polishing residue and old wax to get a good bond for nuba waxs.
  16. pektel
    pektel DB Forum Supporter
    I know lime prime lite is oily. Not sure about Lusso RC. I've used it under DG111 with no issues.
