Old Zanio, Still Useable?
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by Darkstar752, Jul 29, 2009.
  1. Darkstar752
    Darkstar752 Horizon Detailing
    So another forum member let me borrow some Zanio for a detail I have coming up where the guy wants a sealant look. Now, the thing is, it is about 4-5(?) years old, it hasn't even been touched. I'm just looking at Z-2 and Z-5. I shook them both a little, they are pretty much straight water. Are they supposed to be thicker, will they still even been useable after that long?
  2. flash gordon
    flash gordon Banned
    I've never used Zanio, but it sounds like Seperation to me. I wouldn't use it, if you do shake well before every dispense
  3. Darkstar752
    Yea that's what I thought. However, Collinite 845 is very watery too, so I was wondering if Zanio was too.
  4. agpatel
    I would be kind of apprehensive about using a 4+ year old product that has been sitting around. If you have something you can test it on that would let you know if it is still good. Could try it on glass and see if it applies and dries properly. Only issue would be after sitting that long some crazy things can happen to a mixture like a sealant. Has it been sitting garage or inside were the temperature was somewhat stable. I know I had WG DGPS sitting in the garage and after a year it was a liquid, more so that it should be, and would not apply properly and was trashed.
  5. Aesop
    Aesop Jedi Nuba
    see next post.
  6. Aesop
    Aesop Jedi Nuba
    I am sorry I misinformed you. Found this
    Q: What is the usable shelf life of Zaino products?
    A: A 70° room temperature is best for the longevity of Zaino products. Due to the optical additives used, extreme heat or cold can result in a decrease in gloss-enhancing properties.
    When stored at average room temperature between 65° and 75° degrees, shelf life is as follows:
    Z-PC 3+ years
    Z-AIO 3+ years
    Z-CS 5+ years
    Z-1 For optimum results, use before 3 years.
    Z-2 For optimum results, use before 3 years.
    Z-3 For optimum results, use before 3 years.
    Z-5 For optimum results, use before 3 years.
    Z-6 5+ years
    Z-7 5+ years
    Z-8 5+ years
    Z-9 5+ years
    Z-10 For optimum results, use before 2 years.
    Z-12 For optimum results, use before 2 years.
    Z-14 For optimum results, use before 2 years.
    Z-16 3 to 5 years
    Z-18 5 years +
    ZFX For optimum results, keep tightly capped, avoiding moisture. Use before 24 months.
    PM about some sealant options, I can send you some samples for your detail.
  7. GDAL
    GDAL Guest
    Bobby ... I'm sorry that the Zaino was too old. I might place another order soon and you can have a sample. I know you need this ASAP ... the guy might end up liking the opti-seal look.
  8. Darkstar752
    Yea it's no problem dude, I just feel bad that you spent money on something you never used. I'll post your write-up tomorrow, I just have during and a bunch of after, should have taken befores :doh:
    And I think the Opti-seal look will be good too, most of the look comes from polishing anyway. Thanks for helping me out bro :mounty:
