1. Misha
    Misha Nuba Guru
  2. Legacy99
    Legacy99 Wax on..Wax off
    If the new Fein WPO
    14-15 XE is a new machine, how do you know it will last a lifetime?
  3. kc1337
    kc1337 Obsessive Detailer
    The Fein looks like an awesome polisher, now i need to save up more money.
  4. togwt
    Rotary Polishers- a high-speed polishing machine, the high-end machines have a direct-drive with selectable electronic speed control that maintains a constant speed under varying loads conditions regardless of pressure applied.
    • Porter-Cable 7428 - reliable , 10-amp motor, variable speed 0- 3,000 RPM, 9 Lbs weight
    • Metabo PE12-175 – ergonomically sound , on / off switch, feathering variable speed 700 – 2200 RPM, 10-amp motor, 6 Lbs weight
    • Makita 9227C –a reliable workhorse, ‘soft start’ trigger switch and variable speed 600-3000 RPM
    • DeWalt DW849– a reliable machine, 8 Lbs weight, 1000 – 3000 RPM,8-amp motor
    Used mainly by body repair / paint shops or very experienced detailers to rectify more serious paint film surface imperfections using a Velcro baking plate, foam or wool pads of varying coarseness and an abrasive compound or polish to remove swirl marks, scratches and paint defects, using their high (revolution) speed and friction (heat) to enable compounds to abrade the paint film surface that require more power /speed than a random orbital buffer can provide.
    Safety hazards -
    always remember that you are using a power tool that must be given the respect it deserves. As with running any power tool, read the manual and understand how to safely operate it and what its limits are and the potential dangers that could result by using it. Never forget for a moment that given the right conditions, it could kick back and jump out of your hands. Always wear safety glasses and hearing protection. Also, polishing compounds often contain silicates that become airborne in the polishing process, inhaled they could represent real health concerns. Read the safety data sheets and follow safety directions. Personally, I almost always wear glasses, hearing protection, a quality dust filter or mask and a buffing apron when buffing
    Author of 110 in-depth, unbiased “Technical Detailing Papers” and a 560 page "Automotive Detailing, Inside & Out" a knowledge base for the perfectionist TOGWT ™ Ltd copyright 2002-2009, all rights reserved​
  5. PJS
    PJS Birth of a Detailer
    Presumption based on what I've gleaned from users and resellers of existing Fein tools.
    When a company is renowned for its quality, it's taken on face value that they're not about to sacrifice all they've earned and built up through the decades by making something that's a bit DFR - do 'fine' rightly.
    So the confidence is there to suggest it'll last quite some time before it starts to show signs of wearing out.
    This is no different to why people choose Makita, Flex, Festool - they've all built up a reputation for excellent/reliable/dependable products, which comes about through not trading long term reputation for short term profit making/market share.
