Need Help from Computer Dudes
Discussion in 'Detailing Bliss Lounge' started by billyblooshoes, Feb 10, 2011.
  1. billyblooshoes
    thanks for the response! half of that is greek to me honestly, but i've got the general idea of what most of you guys are suggesting, so i'll have to try a few different things.
  2. billyblooshoes
    thanks for the help thus far to everyone else!
    if this helps at all, i'm actually over at my girlfriends house right now, and havene lost signal in hours, and at this point dont expect to. shes running a belkin router, and only has her laptop feeding off of it right now. her's is a toshiba as well.
  3. kyoshiro
    kyoshiro DB Forum Supporter
    your router cant handle your traffic and goes overload
  4. spK
    spK DB Forum Supporter
    just toss the router! trust me!
  5. Kilo6_one
    Kilo6_one DB Forum Supporter
    yeah, when im playing BF2 on my laptop it kicks me off........ sorry for the thread jack, but what do you suggest?
  6. kyoshiro
    buy a better router lol or turn off all the services like SPI firewall, etc especially upnp which increases the load alot
    you can also turn off DHCP server and then set all your IPs yourself.
  7. Emile
    Emile Welcome to Detailing
    Yeah, for whatever reason, routers have too much BS already enabled from the factory. Disable the firewall, any traffic shaping/QoS services as those will literally cap your bandwith and they get very nosey when it comes to constant in/out traffic such as when playing a game. Make sure no ports are blocked, a lot of times the factory settings on the router leave certain ports open for certain games and programs that utilize those ports. Disabling firewall and disabling any blocked ports and traffic shaping will ensure consistent traffic flow.
    If you are concerned about viruses and such, use a software-driven firewall. They are much easier to manage, only downside is that you have to keep on top of each computer's software-driven firewall independantly.
  8. billyblooshoes
    just a little update. the problems definitely that the dlink router cant handle the traffic. if all the other computers in the house are off and im on my toshiba, theres no issue. guess ill pick up a better router and see how that goes.
  9. Kilo6_one
    thanks for the tip!
  10. rfinkle2
    rfinkle2 DB Forum Supporter
    glad to hear you found the problem.
  11. kyoshiro
    routers are getting worse n worse imo
    you really gotta spend the $$$ for a reliable one that doesn't die due to heavy traffic especially from the bit torrent where multiple connections are opened and extra load is on the router
    the general trend of routers are as follows
    cheap and underpowered
    expensive and overheats
    mid priced but crappy firmware
    expensive and overheats and has crappy firmware
    cheap and overheats and breaks very soon
  12. rfinkle2
    could you recommend a router with a good balance of performance and reliability (ohhhh, and price)?
  13. kyoshiro
    id have to say such combination doesnt really exist by my experience LOL
    even the linksys/cisco 310N i have was flueky until i installed a custom firmware (dd-wrt) which improved its performance but the legacy support for G devices is still flakey sometimes. It does suffer from overheating issues as with most linksys/cisco products out there, if you can sort the heat problem (by adding some elongated legs to the bottom) you're pretty safe with their E2000 line.
    I have also tried Buffalo's N-finiti router and definitely lacks in performance at times. Belkin routers are also real flakey, I had their top of the line mimo N router and it had trouble differentiating itself with another router around the area. Asus routers... dead on box opening and quickly dies after exchange from my old roommate's experience. In summary, most big brand router manufacturers had their problems in my experience. Maybe try out Engenius as it seems that they do make some quality routers for industrial usage (tho cisco does as well but they simply have heat troubles). TrendNET, my friend did have good luck with em but I dont know, theyre rather new in the high end home router segment, they've always been the elcheapos.
    If you dont need wireless N and happy with G and on a budget, do get the Linksys WRT54GL and load tomato firmware onto it.
    I've personally ruled out brands like D-Link and LevelOne because they either dont get firmware updates/custom firmware or they simply have tedious firmwares. Not to mention TrendNET is like
    If you do have more budget...
    The one router I would have to praise tho is the Apple Airport Extreme, its expensive but seems to have the most robust factory firmware and reliability.
    There is also a line of router boards that excels in high traffic called Microtik, you'll prob have to buy yourself a few parts and put it together lol.
    So yeah the way it also works out is that if you tend to have alot of traffic and want to keep the same router for long, you buy a more expensive one
    if you want to change routers every year or 2, get a mid priced one
    If you want to lose hair within the first few months, get the cheapest one lol
  14. rfinkle2
    thanks Kyoshiro....you are certainly the one to go to for it info!
  15. Emile
    I am really liking D-Link these days but they're not cheap.
  16. Grey Ghost
    Grey Ghost Jedi Nuba
    did you perform all the necessary windows updates?
    if not, i would do a manual selection of all updates and see if you find an update for your network adapter, or go to toshibas site and look up your lappy's specific drivers and see if there is a driver for the network adapter, if the date on the driver toshiba provides is recent, i would be willing to bet that you have older drivers and the new one could possibly fix this problem.
    i would also advise you to update your routers firmware if you havent already.
