Menzerna Power Lock and Foam...
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by luke093, Jul 1, 2010.
  1. luke093
    luke093 Welcome to Detailing
    Sitting in a closed baggy was an applicator that was used 2 weeks ago with MPL.
    Today, I go and see it as I was using MPL and the foam is torn up! What happened? Why did it happen?
    Don't know why im having a poor experience with this product. First hand application, observing weak durability in lower panels, and now this!
    I really want to like this product!
  2. agpatel
    Hmm, seems that the solvents in MPL do not like being left in a bag with a foam app as it will dissolve it. Note to self wash apps after use and do not place unwashed in baggie.
  3. 911Fanatic
    Interesting to say the least.....
  4. bonehead
    bonehead Jedi Nuba
    How are you washing your applicators/pads?
  5. luke093
    Just dawn then rinsing it out, but its impossible to get out!
  6. bonehead
    bonehead Jedi Nuba
    Regular stuff or the power scrubber?
  7. luke093
    Regular stuff. I do believe that its not breaking the foam down as I wash all my others and none have the same result.
  8. Kokopelli
    Kokopelli Any Rag Vehicle Washer
    This is exacly what had happened with my Megs NXT 2.0 Paste wax and its own pad. I believe I rinsed the foam well but I didn't use an APC or anything else then. After a couple of weeks later I found the foam more porous than it was before and it came into pieces at my hand.
    I now spray some 1:10 APC (VINET from ATAS an Italian brand) onto my foam pads as soon I finish my job, push the foam into it by rubbing with my fingers, and rinse. Cleans up perfectly with no damage at all.
  9. P1et
    What applicator are you using? I have the same thing happen to mine, no matter what product. The Zaino ones are notorious for falling apart, but it's happened with other products as well.
    I would check on your applicators, not so much the product itself.
  10. Marc08EX
    Marc08EX Jedi Nuba
    I clean mine with APC after use and let it air dry. Once dry, I store it in my zip lock bag. Used it twice with no problems.
  11. pektel
    pektel DB Forum Supporter
    Maybe try an MF applicator?
  12. slanguage
    :agree:
  13. nyrep1
    nyrep1 Obsessive Detailer
    i have been using the same blue lc pad washed in zep citrus or opt pc and sealed in a ziplock with power lock since it came out and have had no issues. but you are correct it is impossible to remove fromthe pad
