My bad if this has already been posted. Has anyone worked on matte black paint? Is it polishable? LSP? etc.
if it has a clear coat satin or matt finish why would you need to polish it ? i can see your logic but matt black is just that matt black
I am just asking this hypothetically because I am just curious. But hypothetically, it is a professionally done job.
There are some matte black finishes on my Audi allroad on the top, bumpers, and wheel bulges. From what I've researched and experienced myself, it is best not to polish these areas or clay or any of that other stuff. I normally use a good spray wax to seal them, such as DG AW or Prima Hydro (personal fav). Hope this helps.
we had a flat black "murdered out" e60 M5 at work the other day .. walked up to it to check out the paint work .. i was wondering how the guy even wash's the darn thing
You could use a matte black vinyl overlay (removable) - Index.htm My initial thoughts would be to use a polymer (Zaino Clear Seal) with a polish you would not induce a shine as the paint initially has no shine (on a traditional paint system the colour coats are gloss and the clear coat allows that gloss to show through, the clear coat also has a gloss finish) but you would just level the paint This finish used to be popular with 'Hot Rods' and I should add that I've never detailed this type of paint finish before
Being a custom painter I will give you my experience... You can use a black primer or sealer as your finish coat. It will give you the flat black that is popular. The draw back is there is no UV protection. In about a year the finish will fade out. It will look horrible. Next is to use Base coat/clear coat application. But in the clear you add a flattening agent. Which is basically baby powder. The matt finish is obtained by giving the surface a ruff texture. If you will look at a new Harley with the denim finish with a magnifying lens, you will see pits and craters. There is no light refraction thus giving the matt finish. Now as for the care. Since the surface is so pitted, it will stain easily. I have found that a brake cleaner cleans well, and will not harm the paint. So if you polish the finish, you will be leveling it somewhat and giving the light something to reflect. Thus making it more shiny. As for protection a spray on wax should help. But I would not try and build up the wax. Apply it then strip the next time and re-apply. Your mileage my very.
I guess I'm showing my age, I don't get this stupid craze. Not only does it look FUGLY, it is a pain in the ass to care for...there are no advantages to me, just disadvantages.:shead:
I presume the a flat finish would not reveal swirls and imperfections because the surface is not level. Like anything else, it comes down to taste. I've seen several cars which I believe were tastefully finished in flat black. :shrug: Matte black M5 - Mr. Mota Forums Halfway down the page on the following link is a Mercedes SLR, My E60 - Page 8 - 6speedonline.com Forums
[...But in the clear you add a flattening agent. Which is basically baby powder. The matt finish is obtained by giving the surface a ruff texture....] So forget what I said about levelling the paint with an abrasive polish, by removing its texture it will reflect light i.e. shine
