Layering Pinnacle Souveran Paste
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by detaildoc, May 13, 2008.
  1. detaildoc
    detaildoc Guest
    I added two layers of Souveran to my car, about 1 hour apart and I found that after the second layer it significantly muted the finish (decrease in reflection and depth). Wondering if this has happened to anyone before? :100post:
  2. Sparkie
    Sparkie Wax on..Wax off
    Muted the finish:yikes:... Set it out in the sun for a few hours, pull it in your garage wipe it back down with a QD and a clean MF. That should take care of it.
  3. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    I like to let a nuba "set up" for 24 hours before applying a second coat just for that reason.
    If souveran is let to sit for 24 hours a second coat does enhance the finish, a third coat does not help at all so I would stop at the second coat.
  4. detaildoc
    detaildoc Guest
    Awesome, thanks for the advise. Next time I will wait 24 hours.
  5. FMINUS
    FMINUS DB Pro Supporter
    Souveran is a great wax, but IME I always have had a hard time layering it.
    It never really cures, just sits like a glaze.
  6. detaildoc
    detaildoc Guest
    That's the feeling I got after I layered it. I usually add only one coat, but I wanted to try layering it this time.
  7. trhland
    trhland Nuba Guru
    HERES 3 COATS OF SOUVERAN ..
    i applyed each coat once a week . this is 3 weeks later... NICE AND WET!!! OYAAAAAAAAA
