1. bonehead
    bonehead Jedi Nuba
  2. Darkstar752
    Darkstar752 Horizon Detailing
    :applause2: :applause2: :applause2: :applause2: :applause2:
    I was just getting ready to drop about 100 on a foam cannon and be kicking myself for the price. I'm gonna go pick this up tomorrow, thanks so much!
  3. Darkstar752
    Does anyone have this with a Karcher? Do I need to go pick up an adaptor?
  4. Supertuner
    Supertuner Jedi Nuba
    Do you guys use diluted soap in it or the concentrate
  5. Carn
    Carn Welcome to Detailing
    Interested to know as well :shead:
  6. bonehead
    bonehead Jedi Nuba
    I use undiluted soap. Sucks it up pretty fast, so I wouldn't use expensive stuff.
  7. CU2MIKE
    CU2MIKE Guest
    Hello everyone, new member here. I bought this foam gun and I have the Karcher K2.38, the foam gun DOES NOT FIT the my Karcher. If anyone could please tell me what adapter I need I'd really appreciate it.
  8. CU2MIKE
    CU2MIKE Guest
    By the way, when I say it doesn't fit, I mean it doesn't fit the gun on the karcher, nor does it fit the wand.
  9. bonehead
    bonehead Jedi Nuba
    It's a 1/4 inch quick connect
  10. maximus20895
    maximus20895 Any Rag Vehicle Washer
    oh wow! That's much better than I thought!
    Thanks so much :)
  11. rwisejr
    rwisejr DB Forum Supporter
  12. detaildude3629
    I used mine the other day,works well, uses soap up quick though, did half and half nice foam comes out,, it clings a bit then rolls down, used megs gold class,chemical guys cituis wash and gloss, optimium soap real nice all about the same , worth the $17.88 at my local Homedepot.and i work at lowes..we dont have a product like either..hope this helps.,.also used a gas pressure washer 2500psi, 2.4 gals water a min...thanks:applause2:
  13. CU2MIKE
    CU2MIKE Guest
  14. rwisejr
    No problem
  15. Carn
    +1 :thumb:
  16. Darkstar752
  17. 604_Snooze
    604_Snooze Obsessive Detailer
  18. detaildude3629
    yep thats the one you need to get..good luck will be using it today on wifes nissan sentra car...:applause2:
  19. advs1
    advs1 DB Forum Supporter
    i really do believe you guys would get much better results with DI or even RO water. part of the reason is because tap water has so many damn contaminants that its hard for the soaps to work properly. i noticed a huge difference when i switched to a DI water. now i know DI water isnt the best for PW's, but hey it has been working good for me and my mobile set up for almost 2 years
  20. bonehead
    bonehead Jedi Nuba
    Why do you say that? PW are ideal for DI water. Helps control flow and prolongs the life of the resin. I used DI water (because the water here is hard as rocks) and a PW and it works great. I'd much rather be able to use regular tap water as it would be so much cheaper, but after washing my car with the unfiltered water here just once, I vowed never to do it again.
