Fabric Guards/Protectants
Discussion in 'Interior Car Care' started by agpatel, Jul 2, 2010.
  1. agpatel
    Looking for a good fabric protectant and was thinking of 303 Fabric Guard or 3m Scotch Guard...I knoe CG has one but not really seen anything on it. Any experiences with the above; how did they work, did it seem to last a decent time? I dont want to really have to re-apply often but evey few months would seem like it would not be much issue.
  2. vtec92civic
    vtec92civic Nuba Guru
    used 3m scotch guard and stoners fabritec and both are really great products. they seemed to last a while here but I'm sure usage far as passengers go will have a effect on longevity of the products. maybe climate as well.
  3. togwt
    Fabric Upholstery and Carpet Protection
    Once carpet or upholstery has been cleaned the use of a fabric protector will help to repel grease, dirt, water and oil-based stains. Select a product that contains UVR protection for maximum fade protection, a must for convertibles.
    On outdoor materials (convertible fabric or vinyl) it restores water and stains repellence, resists soiling, mildew formation and helps to protect again harmful UVR and infrared radiation.
    Scotchgard™ -fluorocarbon chemicals (polymer latex) developed by 3M are mostly inert so by applying it to fabric they provide an effective protective treatment by surrounding each individual fibre with an invisible shield. It can be safely used for the finest fabrics, wool, silk, and fine leathers like Nubuck, Alcantara® and suede Scotchgard Protector improves the fibres resistance to oil and water-based stains, as well as soiling from everyday use
    303™ High Tech Fabric Guard - strong enough to protect fabrics in the harshest environment, yet it can be safely used for the finest fabrics, wool, silk, and fine leathers like Nubuck, Alcantara® and suede. On outdoor fabrics it restores lost water repellency and stain repellency to factory new levels. It resists soiling, impedes mildew formation and helps protect against the sun's harmful UV rays.
  4. Legacy99
    Legacy99 Wax on..Wax off
    303 on my seats and outdoor furniture. Last about 4-5 mos. Wear gloves and a long sleeve shirt as the chemical is strong.
  5. Kokopelli
    Kokopelli Any Rag Vehicle Washer
    Gtechniq has one (I1 ?) and if it reaches the claims of their mainstream products like C1 and G1 it should last for a good while.
  6. ps3king
    ps3king Jedi Nuba
    im in need of a good fabric protectant myself. How well does the 303 really repel water?
  7. Chris@Optimum
    I use the 303 on all my boat client's canvas. Its it easy on and works in the harshest conditions. The cheapest I can buy it is at AGO by buying a case of 32oz bottles. Price per 2gallons is $115 shipped...cheaper than the gallon sizes and cheaper than wholesale directly from 303. If you apply 2 coats letting each dry in the sun as per directions, the canvas is almost completely waterproof.
  8. Legacy99
    excellent...water still beads after 4 months.
  9. sal329
    sal329 Nuba Guru
    Finish kare has some protectant I want to try I like everything I have tried so far
  10. agpatel
    I guess I had a brain fart and should of said thinking of using the protectant on a new sofa I am getting so want to make sure it is ok to sit on everyday for long period of time and will not cause issues.
    I am looking at 303 and 3m stuff as I have found no user info on CG stuff yet.
  11. togwt
    Try one of the nanothechnology products-G|Techniq I1 Smart Fabric - based on chemical nanotechnology, it coats individual fibres, which allows the material to breath, while at the same time repelling dirt and liquid. It has no affect on the tactile feel or colour of any fabric and exhibits long term durability
    Smart Fabric protects fabric surfaces effectively from dirt, wine, coffee etc and provides long term protection. Dirt and soil simply rolls off the surface and can be wiped away with a damp cloth with zero staining.
