Dilution mixing machine info.
Discussion in 'Detailing Bliss Lounge' started by razr007, Dec 12, 2008.
  1. razr007
    razr007 Banned
    Hello sorry if this is in wrong place new here.
    I'm going to be going bigger in my detailing venture an want to get a dilution machine so there is no mixing problems for my workers while i'm not in the shop.i wanted to know what companies are out there names ,websites etc. so i can decide what to get. if anyone has any info. on these or has one them selves would like to see it and hear what you have to say. thanks in advance.
  2. togwt
    Ratios (Dilution):
    Dilution rates are shown as a ratio i.e. a solution of distilled water / Woolite® 5:1, this means that the product is diluted five parts distilled water to one part Woolite®. If you have a container with dilution markings fill the bottle with water to the dilution level required and then add product to the fill line.
    Ratios- convert the ratio into fractions. Add the two numbers of the ratio together then use that number as a denominator for the individual parts. Multiply total amount of solution you want by the fractions.
    Example- distilled water to product with a dilution ratio of 5:1 in a 16oz spray bottle >
    (5:1 ratio) 5 + 1 = 6, Water =16 x 5 / 6(0.833) = 13.33 = 13.25 oz. Product = 16 x 1/6 (0.166) = 2.66
    Use 13.25 oz of water / 2.75oz of product.
    Note- 128 oz = 1 Gallon
  3. razr007
    razr007 Banned
    I did not ask for a ratio break down i know how to do that if you read the post again i want a machine to do it from the 55 gal. drums i will be getting.so that no product is wasted or misused from my new workers as they may not know how to mix.i know megs. has a small one.
  4. JohnyB
    JohnyB Birth of a Detailer
    Instead of looking for dilution machine try chemical dispenser or car wash equipment. I have yet to see an all in one setup that mixes product with water that you could just persay fill up the bottle and go.
  5. JLs Detailing
  6. eShine
    eShine Guest
  7. JLs Detailing
    Yeah their website isn't the best in the world. Some products have prices and some don't. Great people to deal with though.
  8. razr007
    razr007 Banned
    I will call them an check it out thanks
  9. SSTG
    SSTG DB Forum Supporter
    ADS has this one
    Meguiar's Metering System
    3 button selector dial dispenses up to 6 different concentrates. Metered, accurate dilutions minimize waste and reduce labor costs by eliminating mixing. Faster fill 5 GPM flow rate for car wash product. Includes tubes, metering tips and label kit. Stainless steel case.
    D-MS3000 $264.95
    Internet Special $199.99
  10. razr007
    razr007 Banned
    yes i saw that one awhile back just getting a feel for what might be better out there.
