Day Of Wool - Little Teaser
Discussion in 'Detailing Bliss Lounge' started by Dave KG, Apr 5, 2008.
  1. Dave KG
    Dave KG Jedi Nuba
    Keep your eyes peeled in the Rotary Polishing section today for some examples of popular machine compounds taken out on wool pads by rotary... Just for entertainment! :D
    Teaser:
    From this:
    To this using MarkV Mystique and MarkV Glisten:
  2. richy
    You got my attention with that product with one of your recent show and shines. Too bad it didn't remove the hole...hahhahaha
  3. sly
    sly Birth of a Detailer
    Wow! Thanks DaveKG but can i do with PC?
  4. Dave KG
    Dave KG Jedi Nuba
    Wool on a DA I wouldn't personally recommend as the tools dont have the power to wor the compounds and the wool properly... rotary polishers have a lot more power at this level.
    Faced with marks like that on a DA, you could either perservere using a slow cutting technique with a compiund such as Power Gloss on foam, or you could wet sand using a foam based sanding disk and the polish out the sanding marks which result with a medium abrasive polish on a foam pad. The latter requires a lot of practice and the potential for damage really quite high unless you are confident with it, but the correction is possible.
  5. pirex
    pirex DB Certified Dealer
    Very nice Dave! I should start to use wool more often, been a while since last time!
  6. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    You should Pirex, wool is the way to go.
