Black Hole and QD +
Discussion in 'Car Detailing Product Discussion' started by agentf1, Apr 2, 2008.
  1. agentf1
    agentf1 Jedi Nuba
    Thanks cwcad, very generous of you.
    If you are a carnuaba guy these are two very nice products and I would say a must have. The glaze is very nice on darl colors and had good hiding capabilities for "minor" swirls and really left the paint very reflactive and leaves a beautiful finish. It was grayish purple and had a grape odor, it almost reminded me of DWG or EZ C and I am guessing it may be a reformulation of or even a blend which is not a bad thing since I thought both of those glazes were excellent as well. Similar to both of them it went on very nice and also was very easy to remove using a mf towel providing you worked it in well. I aplied it with qa mf app and removed it with a mf towel. I also topped with Concorso which made it really look awesome, very clear and reflective.
    I also tried the QD+ whick was actually thr same color and fragrance. Alomost looked like a watered down BH. It required a little more work than a straight QD but seemed to leave a real nice finish and actually add additional gloss to the finish similar to the BH which made it worth it.
    So, if you are a carnuaba Guy, and own a dark car give them a try.
  2. Dave KG
    Dave KG Jedi Nuba
    Interesting review, thanks for sharing. Just seen them arrive at a UK trader and was contemplating the Black Hole to try alongside my other glazes.
    How would you say it compares with my personal favourite, Meguiars #7?
  3. Pats300zx
    David...BH is much easier to use than #7. As you know one of the best ways to remove #7 was to "skin" it on several passes around the car. BH is much easier to use and looks just as good.
  4. FMINUS
    FMINUS DB Pro Supporter
    I have all 3 of these products.
    Good Alternatives are:
    CG EZ Creme
    CG Pro Detailer w Carnauba
    I have problems with streaking w the QD, take warning I am the master of streaking...
  5. agentf1
    agentf1 Jedi Nuba
    I agree, just as nice a look and MUCH easier to use.
    Are you using a MF app for the Glaze? Sounds like you are not working it long enough.
    What towel are you using for the QD? I am using AG's big blue plush towel and it works great. You also need to watch how you are washing your towels, no fabric softener etc...
    I could see the QD+ being a little more prone to streaking since it contains product but I have had no issues to date. It also says it can be used in the sun which I will believe when I see it but will have to give it a try.
    I really don't recommend using any product in the sun but will say that I did use Revive and BW in the sun once when I was in a pinch and could not find shade and it did work to my amazement. That is probably the only quality I did like about the Revive and BW.
  6. Dave KG
    Dave KG Jedi Nuba
    Cool thanks for that.
    #7 I do use a lot, it isn't always the easiest to remove but I've never had loads of problems: use two mfs, one to remove the majority by continually varying the wipe direction to break the skin up, and then a second clean one to buff.
    An easier to use product would be good though, BH will be trialled by me soon :)
  7. zoomzoom mazda5
    zoomzoom mazda5 Wax on..Wax off
    I got to try PB QD+ at DF this past weekend from Steve, and i did my car and it had a very nice shine to it and felt very slick too.
  8. FMINUS
    Just the QD streaking not the glaze
