Applying wax.....
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by 911Fanatic, Jul 11, 2010.
  1. 911Fanatic
    I have had a few enquiries as to how much wax is too much when applying it. I took a few sample pics to hopefully help you guys out.
    My friends GTi served as the test bed. Here, freshly polished hood.
    Foam applicator pad and jar of Vics Mayhem (soft wax)
    After gently pressing down the applicator onto the wax, this is what the pad looks like. A very light coating of wax. If it was a hard wax, you would gently rub the applicator across the wax.
    I apply the wax in small circles. Notice that you can still see the reflection of the lights after the wax is applied. If you can't see the reflection clearly, its too thick. When you apply it, it should look oily, but still transparent. Each wax has different rules for when to remove. Check the instructions for your particular product.
    Hope this helps.
  2. Emile
    Emile Welcome to Detailing
    Nice post, Ken. I like working in small circles as well. Allows me to spread the product as far as possible to apply it very thin, and minimizes/eliminates any high spots so removal is easy breezy.
  3. Frankastic
    Thanks Ken
  4. kc1337
    kc1337 Obsessive Detailer
    I apply in straight lines.
  5. Great Thread Ken :applause:
    I see this issue come up more times then just about anything else. Now I have a link I can shoot in someones direction. Thanks Ken :claping:
    I also apply using the straight line method. I start in the center of each panel and work my way out to the edges. I will start out with minimual product, and give a quick swipe of my app pad to my product when nescecary :paranoia:
  6. christian900se
    I use a mix of straight line and small circles when applying waxes, although some I use the circle technique exclusively such as any of the Collinite paste waxes because it helps them spread further with less effort.
  7. bonehead
    bonehead Jedi Nuba
    Any tips on hand application of carnuaba?
  8. matrix_808
    matrix_808 DB Supporter
  9. metajames
    metajames Birth of a Detailer
    I think that's exactly the point.
  10. matrix_808
    Well I was assuming the person was referring to bare hand application and not application via applicator.
  11. metajames
    LOL I suppose that could be it too... :shead:
  12. bonehead
    bonehead Jedi Nuba
    Thanks and yes, that is what I meant:fs:
  13. KenB
    KenB DB Forum Supporter
  14. vtec92civic
    vtec92civic Nuba Guru
    im not a ford focus person but damn that focus is pretty damn nice.
  15. Yea, I know :giggle:
    Well, I just assumed everyone had expierence doing handjobs :duh:
  16. Reflect
    Friction is key to making sure it spreads evenly. I haven't done it, but I heard it's more of a "thing to do" rather than beneficial.
  17. P1et
  18. togwt
