1999 Formula Red NSX Perfected!
Discussion in 'Show and Shine' started by d00t, Mar 8, 2009.
  1. d00t
    d00t Welcome to Detailing
    This was a long one.. spent a little over 30 hours on the car, including wetsanding. I cleaned/conditioned as much of the vehicle as possible, trying to restore it to better than new condition. The car used to be well taken care of, but when the owner moved to downtown SF, he wasn't able to wash it on his own, so it frequented the "down the sreet" washes :crasy::yikes:.
    Upon inspection of the car 3 stories below the ground, it was in really good shape. Exterior barely having any fallout, looking decent (considering the rains we've had lately). The interior was immaculate minus the dirt on the floor mats. After taking the car home, and storing it for the night I was ready bright and early on Tuesday. I woke up to pouring rain. Even though I could have washed the car inside.. I wanted to do as much of a thorough degreasing as possible, so it was all done outside.. in the rain. Even with snowboard pants, and a rain coat, I was still soaked! At least it wasn't snow, huh? ;). Sorry I look a little ridiculous.. I was more concerned about staying dry!
    First things first was a thorough pressure rinse on the outside:
    After this I turned my attention to the wheels. Per standard procedure the tires were soaked in P21S TAW, and the wheels received P21S Wheel Gel.
    And then agitated with various brushes:
    After the wheels were finished, I moved on to the initial foaming of the car. Because the car wasn't super soiled (for a change) I foamed it with Chemical Guys' Citrus Wash and Clear, and then washed with the 2BM and Citrus Wash and Gloss.
    (my baby in the very background getting DRENCHED :( ).
    And then the car was pressure rinsed one more time before being brought inside where I blew it dry. Yes, INSIDE! It was raining so hard.. it wasn't even worth trying to dry, let alone blow dry outside. So I did it in the garage with very good results.. just a little bit of water ;).
    After it was dried. I continued on with decontamination. The car was clayed with CG Blue Mild clay, and Luber as clay lube:
    ..And the wheels:
    ....Annnd the Door Jambs:
    And the deck lid/hood and jambs:
    After this I turned my attention to the spare tire. It was rinsed, then cleaned with P21S TAW and Wheel gel + Swissvax Wheel Brush/Megs Slidelock Brush:
    My attention was then turned to was was UNDER the spare tire. The area where the engine compartment usually is.
    Certain soiled areas were carefully saturated in P21S TAW and let sit before agitating away and wiping clean.
    I then turned my attention to what was under the boot lid.. AN ENGINE! Everything was thoroughly degreased with P21S TAW, SW Wheel Brush, Q-Tips, and a lot of elbow grease. Then wiped clean.
    Towards the end of day one a big scratch was found, and I decided to relevel it to make it less apparent.
    So it began..
    Then I called it a night.. to sleep on when I just did :thud:. The next two and a half days (20 hours total) was spent on the paint correction. Here's a slew of befores:
    Then the sun decided to show for some 50/50s! These shots show the test panel which was corrected with the KB Method of Foam compounding: m105+cutting pad w/ primed pad @1200rpm, then finished with m205+finishing pad with pad primed at 1200-800rpm. As you can see.. slight hologramming still shows and it was brought back in for more testing of polish/pad combos after I saw this.
    After seeing this the car was brought back in, and I settled on this combo. 3M UK Green+SIP @ 1200-1800-1500, then 3M Yellow+106fa @ 1200-1600-1400, and lastly 3M UK Blue+Ultrafina @ 1200-1500-1200-900. Overall the results were about 95%. There were some deep RIDS that the owner and I decided I wouldn't chase because of the notorious thin Honda clear, and also we still want to be able to finish polish the car if need be down the road. I especially enjoyed the Formula Red tint on my pads from the Tri-Clear paint on the Formula Red hondas!! These were the results:
    All of the black trim got the same attention, taking special care with extra taping as to not catch any edges..
    Results:
    Moved up to the roof..
    (those scratches in this pic are these: [​IMG])
    I then opened the garage door and got a few quick sun pics:
    While making my way around the car I took the time to polish out the tail lights with 2x SIP+Green and 1x UF+Blue:
    The I continued with the rear bumper with said process in the beginning..
    The importance of taping. The $5 roll of tape is a $1000+ insurance. This would have meant a new bumper+repaint if the tape wasn't there..
    B-pillar before:
    After:
    Fender corrected, door not:
    The importance of taping!
    Under the wing:
    Going after it with a Orange CCS Foam Finger Pad+M105:
    And where the "diffuser" is:
    ZAIO+White CCS Foam Finger pad in the door jambs:
    And under the hood:
    After these minor details were finished I was done!! Brought it outside to give it a thorough pressure rinse that was filtered with DI water to get rid of all the polishing dust:
    Before any LSP:
    After all the rinsing. It was brought in for a "two stage" lsp. The first of which was Danase Wet Glaze applied with a dampened Blackfire Gold CCS Pad:
    My back that is in as good a condition as a 60 year-old (threw it out years ago, and it's never been the same since, and polishing for 8 hours straight), was aching so I took a rest from bending over/lsp application and paid attention to the wheels. For thise, I removed as much oxidation from the cleared lips as possible with Mothers Mag&Aluminum polish. Then I polished them with Werkstat Prime Strong, Acrylic Jett, and the Acrylic Glos.
    Before:
    After:
    Then I turned to the interior. I just wiped down the leather part of the dash, and applied Leather Masters Protection cream. All of the vynil got 303 Protecant. The seats were treated with Leather Masters Trio. I'm horrible with interior before/afters so there aren't any. But I did take pictures of the floor mats! They were vacuumed with metro vac'n'blow and then cleaned with CG Citrus Carpet Cleaner and SW Leather Brush.
    Before
    After:
    Before:
    After:
    (excuse the lack of prison stripes on the other mat, they were added after this pic).
    Then I moved on to the LSP. It received Swissvax Concorso:
    (pic taken after it was applied/removed).
    "Detailers Best Insurance":
    And the afters. Sorry for the lack of pictures, I didn't finish until late last night, and when I delivered it today, we were in the middle of the street :p. So no afters of the engine bay/hood area which I spend 6 hours total on :shead: . And none of the interior area.
    But I *DID* get the most important parts.. the body of the car!
    (the owner and my gf in the background).
    Done!! :thud:
    C/C Always Welcome! :applause2:
    Aaron
  2. Buddy
    Great detail and write up. You did a fantastic job. It looks just beautiful...:thumb::thumb::thumb:
  3. SSTG
    SSTG DB Forum Supporter
    Great job Aaron.
  4. Darkstar752
    Darkstar752 Horizon Detailing
    Very nice, that color looks awesome now :mounty:
  5. LanceM
    LanceM DB Forum Supporter
    looks great. nice write up as well
  6. Nica
    Well done, red colour vehicles are usually tough to photograph defects on them but you captured them quite well, well done :thumb:
    That vehicle looks great, just curious did you take some paint gauge readings? I'm just curious to see what the readings range from that's all.
    I've seen some of these NSX's in person and pictures don't due justice to these vehicles.
  7. P1et
    Beautiful work! Love the license plate as well, very nice!
  8. d00t
    Thanks!!
    Thank you sir!
    Thank you!
    Thank you Carlos!
    Don't hate me.. but that's the reason I had to sleep on what I just did.. I didn't have a PTG with me. One's on order, and Denzil's letting me borrow his for the coming detail I have on an IS250 that will need wetsanding. When I get one, I'll be sure to take readings of the "aftermath" because he's now a regular!
    Thanks! You weren't supposed to see that for securities sake :p: . I'm gonna fix it now..
  9. Hostage1978
    Hostage1978 Guest
    Have to agree, such a beautiful car in person.
    Beautiful write up, thanks for sharing
  10. Nica
    Oh no worries, I didn't mean to put you on the spot, I was just curious that's all :peace:
  11. 911Fanatic
    Very nice Aaron. That red looks fantastic.
  12. Denzil
    Looks great Aaron! I have that PTG waiting for you! :)
  13. J BELL
    J BELL Nuba Guru
    Dam!!! That made me tired just watching you in all the pics...wheeew i need a nap! Looks excellent bud!
  14. supercharged
    WOW! I'm speechless! its jaw dropping awesome! That red is glowing! How do you like Concorso wax so far? What can you compare it to?
  15. krshultz
    krshultz Nuba Guru
    Another ace job Aaron, nice one!
    I have a question. You showed pictures of yourself polishing the small, painted, gloss black pieces of trim on this car - around the windows and whatnot. Would you mind sharing your technique? Pad/polish selection, and especially buffer speed.
    Areas like this still make me uneasy. Even with thorough taping of the surrounding areas, I always scare myself away from putting the machine on something so small. Now that I've seen that it can be done, would you mind helping us (me) out?
    Thanks man!
  16. SpecC
    SpecC Wax on..Wax off
    aaron you've got to show me how to wet sand some time!
  17. Denzil
    Ah yeah, I was actually curious about Aaron's technique too. I guess I'll just have to ask him when he picks up my PTG. :giggle:
  18. Wolfs Chemicals
    Very nice work, Aaron! I've always been an NSX fan!
  19. d00t
    Thanks!!
    I understand! :thumb:
    Thanks, I appreciate it!
    Thanks Denzil! Can't wait to get it tonight :D. I'm kinda curious about my S2000 paint as well...
    Thank you! At least you didn't have to work on it for 30 hours ::p:
    Thank you!!
    As far as techniques go.. just treat it like the rest of the car. Unlike the one-off scuderia's, enzo's, rolls, bentley's, aston's, etc. These aren't hand painted, and therefore are pretty cosistent as paint type goes. So if it's super soft on the door.. you better believe the trim will be super soft ;). I just tape a lot, and take my time with the 80mm 3M UK Pads. Instead of going up to 1800rpm, I may only go up to 1600 because heat can't be spread over a large panel much like it can on a door or fender. Also, with the small pads, the heat doesn't build nearly as fast as a larger pad. The same process was used on these as the rest of the car with outstanding results. Also, some parts I couldn't reach and were hand-polished (like right behind the mirror). Maybe Carlos, with his close ties to the old machine shop, can make an adapter that extends the length of the spindle so we can get in to tight areas without the enormous makita getting in the way :p.
    Will do! It's really not that hard.. it's more of a conscience thing than "skill" like finishing down 100%. I actually learned to be very effective at it in a day from Bob @ AutoConcierge. He was a really great teacher and explained WHY you sand a certain way, instead of the youtube vids that say "just do it this way 'cause"
    Read above :p
    Thanks Jesse! I love it.. but I think I'd want an NA2.. wasn't a huge fan of the NA1 :tiptoe:
  20. krshultz
    krshultz Nuba Guru
    Thanks Aaron, that helps a lot.
    Is this the car you were working on when your 3M green pad disintegrated?
