Winter - Salt Removal Wash and Protect services offered at our location. Helpful Winter Tips: Keeping your vehicle as clean as possible during the winter will go a long way to cut down the damage done by salt and sand. Wash your car often - if you can't in your situation find a self operated/ touch less. Steam cleaning or power washing your undercarriage is a plus! Have your car re-waxed and sealed when you have it washed. Make sure the car is completely dry Carefully dry the edges of the doors inside and out, including the undersides of door handles, all hinges, plus the hood and trunk edges. This helps keep them from freezing shut. Use a good quality spray protectant on all exterior rubber or vinyl surfaces. It may be best to spray they applicator you are using instead of spraying the product directly onto the surface. This will avoid any overspray onto the paint. This BMW 435 X Drive receives a salt removal wash and protect. Salt Removal - Wash and Protect Our special pre-soak was designed to chemically remove the majority of the salt and road grime off the paint, with our touch less approach we are preserving the condition of the paint. After shot Porsche Cayenne Turbo Mats - Salt Removal Before After Call or email us to get your car in. Phil@DetailersDomain.com 201-768-1818
My cars are so dirty!!! I cringe at taking them to the hand wash, wish you were closer LOL. I might wash them in the rain tomorrow lol
What's your pre-soak mix? Say it has OptiCoat on there, what would you use to be as safe as possible?
If it's opti coated, I don't see why you can't use an APC mixture like Adams with a pre soak like AF Avalanche in a foam cannon. And for tough spots I've had great results with AF citrus with a high pressure rinse. Although neither of those seems to be what Phil did on this wash.
our presoak is done so we don't "touch" the car as much. that being said we do a traditional wash after we remove 70% plus of the salt and grime. Presoak is a combo of P21S Total Auto Wash Sonax Fall Out Remover Then a final foaming with Auto Finesse Avalanche if your foam gun/cannon. After a good spray wax/sealant - for this service at the shop we use Sonax Brilliant Shine Detailer
2007 Audi RS4 receives a Salt Removal Wash and Protect 2007 Audi RS4 receives a Salt Removal Wash and Protect
I was finally able to wash both my DD's today. Rinsed with fireman's nozzle (no power washer yet, on my list) Foam cannon with CG Citrus Wash and Gloss Rinse again Pre-soak with Durgaloss Rinseless with Aquawax Wash with mix of Duragloss RWA and 902 Dry with MF WW towel and Megs D156 Both came out great, but ton of tar and iron specs even though both are coated and topped
we have been using decon gels on coatings and if the coatings are installed correctly there will be no negative effects on it
