Winter Car Care: Get Ready for the Season with Nextzett Products
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Michael@nextzett, Dec 17, 2024 at 11:46 AM.
  1. Michael@nextzett
    Michael@nextzett DB Certified Manufacturer
    As winter approaches, it might feel like car detailing can take a backseat. But with mud, dirt, and corrosive road salt on the horizon, it’s not just about keeping your car looking sharp—it’s about protecting it for the long haul. From your paint to your interior, a few preventative steps can save you time, money, and effort when spring rolls around.
    Here’s how to prep your car for winter using key products from Nextzett.
    Step 1: Pre-Wash to Remove Salt and Grime
    Product: Lotus Ultra ISF Pre-Wash
    Winter roads can leave behind layers of grime, salt, and debris that damage your car’s finish over time. Start with a pre-wash cleaner like Lotus Ultra ISF, which is biodegradable, eco-friendly, and tough on road salt and stubborn dirt. Use it regularly to prevent salt buildup and reduce the risk of corrosion.
    Pro Tip: Pre-washing ensures your main wash is more effective and saves you effort down the line.
    How to Use:
    - Dilute Lotus Ultra ISF (1:5 for wheels or adjust to 1:10 for lighter grime).
    - Spray onto the affected areas and let it sit for a few minutes.
    - Rinse thoroughly before proceeding with your favorite car shampoo, such as Auto Glanz Shampoo or Lotus Ultra Power Foam.
    Step 2: Protect the Paint Finish
    Product: SF3 Premium Protect
    SF3 Premium Protect is a polymer sealant wax designed to create a high-gloss, durable barrier against winter’s harsh elements. It repels water, dirt, and salt for up to six months while protecting your car’s paint from contaminants like brake dust and acid rain.
    Pro Tip: Reapply after a few washes or heavy snowstorms to maintain the best protection.
    How to Use:
    1. Wash and dry your car thoroughly.
    2. Apply SF3 with a microfiber applicator pad.
    3. Buff to a glossy finish with a clean microfiber towel.
    Step 3: Safeguard Your Interior
    Product: Cockpit Premium
    Your car’s interior endures mud, slush, and salt during winter. Cockpit Premium not only cleans but also protects surfaces from UV rays—yes, even in winter. For heavily soiled areas, pre-clean with Plastic Deep Cleaner before finishing with Cockpit Premium for a non-slippery, matte finish.
    Pro Tip: Use Cockpit Premium on rubber floor mats and textured plastic surfaces for added protection. For soiled mats, pre-treat with Plastic Deep Cleaner before finishing with Cockpit Premium.
    How to Use:
    - Spray directly onto a cloth or the surface, then wipe clean.
    - For textured areas, spray onto a brush and scrub gently before wiping dry.
    Step 4: Shield Your Upholstery
    Product: Lotus Ultra Textil Protect
    Winter messes like muddy boots, spilled coffee, or melted snow can leave your upholstery looking worse for wear. Lotus Ultra Textil Protect creates an invisible barrier that repels liquids and stains, keeping fabrics fresh.
    Pro Tip: This product isn’t just for cars! Use it on jackets, shoes, and other winter gear for added water resistance.
    How to Use:
    1. Clean and dry the fabric before applying.
    2. Spray evenly and work the product into the surface using a foam applicator sponge for thorough coverage.
    3. Allow the treated surface to dry thoroughly before use. Reapply periodically for continued protection.
    Step 5: Keep Weather Seals Flexible
    Product: Gummi Pflege Stick
    Freezing temperatures can leave door and trunk seals stuck or damaged. Gummi Pflege Stick keeps weather seals pliable, reducing the risk of freezing and improving insulation.
    Pro Tip: Regular use enhances noise reduction and keeps cold air out.
    How to Use:
    1. Wipe weather seals with a damp cloth to remove dirt, dust, and debris for optimal application.
    2. Apply Gummi Pflege using the built-in foam applicator.
    3. Glide the applicator along seals for even coverage.
    Step 6: Protect Tires and Trim
    Product: Vinyl-Rubber Extra
    Road salt and grime don’t just harm your car’s paint—they also damage plastic trim and tires. Vinyl-Rubber Extra provides a protective layer to keep these surfaces looking their best.
    Pro Tip: Reapply after heavy snowfall or extended salt exposure for maximum effectiveness.
    How to Use:
    - Apply with a foam applicator pad.
    - Work into the surface until fully absorbed.
    Step 7: Enhance Visibility
    Product: Glass Sealant
    Clear vision is essential for winter driving. Glass Sealant repels water, snow, and frost while resisting car wash detergents for up to six months.
    Pro Tip: Pair with Anti Frost Washer Fluid Concentrate for optimal performance in icy conditions.
    How to Use:
    1. Clean glass thoroughly using Windscreen Clear glass cleaner. For stubborn stains like hard water spots, opt for Glaspolish to ensure a streak-free finish.
    2. Apply Glass Sealant with a microfiber applicator pad.
    3. Buff with a damp microfiber towel to remove haze.
    Bonus Winter Tips
    1. Check Your Tires: Ensure proper tread depth and consider winter tires for icy roads.
    2. Replace Wiper Blades: Swap out old blades to maintain visibility.
    3. Stock an Emergency Kit: Include essentials like a blanket, flashlight, and jumper cables.
    4. Monitor Battery Health: Cold weather drains batteries faster—test and charge as needed.
    5. Inspect Heating Systems: Freshen up your heater and defroster with Klima Cleaner ETU if odors persist.
    Prepare your car for winter with Nextzett’s range of products and take your car care routine to the next level. Visit DetailersDomain.com to shop and learn more.
