Will my micro fibre cause scratches - Testing Micr
Discussion in 'Car Detailing Product Discussion' started by togwt, Mar 20, 2010.
  1. togwt
    Testing Micro fibre
    A couple of ‘non-scientific test’ you could use to assimilate wither or not a towel will cause scratches, they are not at all scientific nor 100% accurate, they are only indicative of what the towel may do to your paint surface, but then which is preferable to scratch a CD or your paint surface? Ensure the towels have been washed before carrying out these ‘tests’. If the towel does scratch the CD’s surface that doesn’t necessarily mean that it will scratch the vehicles paint, a CD has a much softer surface than automobile paint so use caution, initially trying an inconspicuous area
    CD Scratch Test
    Take a damp micro fibre cloth and use medium to heavy pressure rub the data surface of a CD. If no scratching is evident then it probably won’t scratch the vehicles paint surface, be aware that the bindings can also cause scratching. Ensure you wash before you use a micro fibre towel for the first time and use it on an inconspicuous area first.
    Burn Test
    But not all microfibers are polyester. There are microfibers made from cotton, rayon, acrylic and nylon. Most of the time, though, the fibre is polyester a simple burn test will tell you which fibre the product contains A very easy test is to take a butane lighter and put the fibre close to the flame, but not in the flame. If the fibre pulls away from the flame, you have a synthetic fibre (nylon or polyester, most likely).This means you can easily clean the fabric with typical aggression. If the fibre does not pull away, burn it. If the resulting ash is crumbly and gives you a "dirty finger" when you crush it, you no doubt have a natural fibre
    An extract from one of a series of unbiased Detailing Technical Papers, a library of educational materials that has become the #1 reference for car care on the Internet
    © TOGWT ™ Ltd Copyright 2002-2010, all rights reserved
