Who needs Iron X?
Discussion in 'Car Detailing Product Discussion' started by cptzippy, Apr 4, 2011.
  1. cptzippy
    cptzippy Jedi Nuba
    As I started to look at the forums again this spring, I noticed Iron X mentioned a lot. I get the idea of it but when is it really necessary? If it is something I should get, do I need to get the soap or the liquid?
    Basically, I need an Iron X primer :)
    TIA,
    Tony
  2. billyblooshoes
    hey welcome back around. just get the iron x liquid/spray. its for iron deposits on automotive surfaces...IE rail dust. can also be used on wheels as a secondary cleaning for iron deposits.
  3. domino
    domino Welcome to Detailing
    i dont really get it either
    i did get a sample of the iron x wash that ill use prior to applying cquartz
    but this whole iron x deal, so what was everyone using for iron deposits prior to this?
  4. mrgolfrider
    If prior iron deposits are rail dust deposits, an aggressive clay was typically used I thought.
    Sent from my HTC Vision using Tapatalk
  5. christian900se
    Yep, it lets you skip using an aggressive clay which helps you avoid inducing marring during a decontamination process.
  6. kyoshiro
    kyoshiro DB Forum Supporter
    sonax FE on paint yes yes?
  7. Kaban
    Kaban Welcome to Detailing
    I was thinking the exact same thing.... someone needs to try it. It should work without issues since it's PH neutral.
  8. kyoshiro
    troy once told me it works
  9. Emile
    Emile Welcome to Detailing
    I tried it, Sonax doesn't do anything on the paint.
    I know that IronX is presented as this essential step before claying, but I actually use it quite frequently as a pre-wash. I spray it onto the lower panels, let it turn red, and then pressure-wash it off and it knocks out the dirt without taking the wax with it.
    IronX Soap Gel is pretty nice also. Super LSP-friendly while cleaning very well.
    So for me, as a recreational/hobbyist car washer, I think the IronX products are really nice just for maintenance washes. And from what I understand, a lot of professional detailers use IronX for a more advanced/thorough method of paintwork cleansing.
  10. AutoObsessed
    AutoObsessed Dealers
    Yup I have tried it, no problems but I didn't have any IronX available at the time. IronX is cheaper and is my first choice for this purpose.
  11. Cobalt9123
    Cobalt9123 Virgin Detailer
    Sonax DOES work on paint...for those who wanted to know--IronX and Sonax are very similar in their chemicals at the roots; however,personally believe that IronX and IronCut are more aggressive than Sonax.
    You use such a chemical when you have embedded iron contaminants in paint caused by rail roads, industrial fallout, certain exhaust systems, and certain brake dust. Claying is extremely tedious and time consuming when removing embedded iron particles and can also induce some crazy marring.
    It's the best thing since sliced bread for those of us with high-performance brakes/exhaust on white vehicles :)
  12. Kaban
    That is VERY weird considering so many factory and after-market wheels nowadays are painted and clear coated very much like the paint on a car...so I would assume if it works on painted wheels it will work on any painted surface.
  13. M3ride.
    M3ride. Wax on..Wax off
    I got painted wheels and yes Sonax does work very well. So it must work on paint too but I don't think I'd use it for that. But that's just my opinion.
  14. kyoshiro
    all my wheels are painted + clearcoated (Hurrah OEM) and sonax works fine
  15. Cobalt9123
    Agreed. In my experience, it works perfectly fine on paint. If it didn't work on someone's paint maybe there were no iron contaminants...
  16. billyblooshoes
    beg to differ. ive tried it multiple times, and it did work. first was a white car, so the results were obvious.
  17. Kilo6_one
    Kilo6_one DB Forum Supporter
    may have to buys some more sonax.......... what is the dwell time?
  18. Cobalt9123
    A couple of minutes. The green foam will turn red when reacting with iron and other deposits and it should be pretty obvious when it's time to rinse it off. However, it is pH neutral so no worries if it dries.
  19. detailersdomain
    guess I'll have to try the Sonax again I couldn't get the results I wanted on the few cars I did.
  20. sal329
    sal329 Nuba Guru
    Why use Sonax on paint if Iron X is cheaper? Unless I am wrong about price? So Iron X will not remove an LSP?
