Whats your go to AIO?
Discussion in 'Car Detailing Product Discussion' started by eacmonroe, Dec 5, 2012.
  1. eacmonroe
    eacmonroe Virgin Detailer
    I recently picked up and tried the optimum poli-seal. Didnt Blow my mind but also didnt dissappoint. It cleaned the paint up pretty well but left swirls. Im looking for a go-to All In One product that i can offer for the "in-betweeners" at my shop that dont wanna pay for a correction or 2 step, but need more than just a wax. I looked at the AF Tripple, it looks like it has great cleaning potential. Also...can the tripple be put on by machine instead of just by hand? Thanks!
    Jeremy - Executive Auto Care
  2. vtec92civic
    vtec92civic Nuba Guru
    Before i finished reading your post i was going to suggest Tripple by AF. I'm pretty sure it can be applied by machine. Check with Phil as he uses it on a more regular basis. I believe Franki uses that too aka overtimedetailer.
    Poli Seal didn't impress me much. I still have the bottle i baught a year ago. It cleans the paint well as you said but its not really for correction purposes.
  3. eacmonroe
    If tripple can be applied by machine that would be great! Ill have to check. Other than the Tripple and the optimum, is there anything else anyone has used? I see the XMT 360 that pinnacle sells is an all in one also. Has anyone tried that?
  4. DirtyWeRX
    DirtyWeRX DB Forum Supporter
    Tripple is one of my favorite AIO, However, it really lacks durability. Yes, you can use it by machine.
    Werkstat Prime Strong is probably the best at cleaning the paint. use it with a light cutting pad that you dont particularly care for as it will stain it.
    I just used Klasse AIO for the first time yesterday and was rather impressed with how easy it was to use.
  5. EbbeJ
    EbbeJ Jedi Nuba
    I like Wekstat Prime Strong and Zaino AIO.
    Kind regards,
    Ebbe
  6. Meticulous-Detail
    Megs D151 and Duragloss 501
  7. shawn05sti
    shawn05sti Virgin Detailer
    I love werkstat prime as well.
    But my latest go to is Wolfs Shine and seal. With a white pad I can correct soft paints and give solid protection. It cleans the paint excellent as well and that little bottle goes pretty far if used right.
  8. dogma
    dogma DB Forum Supporter
    WOLFS Shine & Seal Prima Amigo HD Speed
  9. JOMAX
    JOMAX Two Bucket System Washer
    Meg's D151 and duragloss 501
    Sent from my iPhone using
    TapTalk
    2000 Black DRW F-350
    Gauges, DP tuner, ported housing, T-500:evil:, JW VB, 5in turbo back, hutch/harpoon mod, 6.0 IC, tru cool tranny cooler, etc
  10. Kilo6_one
    Kilo6_one DB Forum Supporter
  11. Jumbo Jet
    Jumbo Jet Jedi Nuba
    Klasse AIO
    FK 1 #425 AIO
    Zaino AIO
  12. junebug
    junebug Jedi Nuba
    I'm not a big fan of AIO's, but I do like KAIO for certain colors like flat white - think GM and Honda. I think D300 followed by BFWD would
    be an ideal for the customer that needs a good polish/wax. Both are easy to use, even "junebug" proof! I will say that IMHO, for best results, use an air compressor to clean the MF pad after each panel. makes the D300 work better. And keep a dedicated LC Gold pad for the BFWD, it will NOT clean out of a pad, at least nothing I've used will do it.
    Poxy users don't have that issue.
  13. eacmonroe
    How is everybody applying their aio? Typical polishing method with an orbital? or are you running it at a lower speed (3) because of the carnuba thats in most to leave a protection?
  14. DJBAILEY
    DJBAILEY Birth of a Detailer
    Finish Kare 215 AIO has a lot of cut to it for an AIO. I use it with a rotary and a white LC Kompressor pad for my minivan specials. Then top it with FK100p wax/sealant.
  15. Jumbo Jet
    Jumbo Jet Jedi Nuba
    Oops, I said FK 425, I meant 215. I use it with a white LC pad, PC or Flex on 3. Same with Klasse or Z-AIO
  16. GDAL
    GDAL Super Moderator
    I use D151 for medium/hard clears and Opt GPS mixed with OPT Polish for softer clears. D151 and mf polishing pads & uber yellow pads work really well and you can get decent cut for an AIO. IMO, Poliseal looks a little bit better than GPS (not by much though), but it's a PITA to remove from pads. GPS doesn't have that issue.
    I have a bottle of HDSPEED and Wolf's Shine & Seal that I need to try out soon.
  17. cu2mike
    cu2mike DB Forum Supporter
    I don't have a go to AIO..... It just really depends on my mood, lol.
    Prima Epic, Amigo, Scholl A15, Werkstat Prime Strong, AF Tripple to name a few.
  18. SonOfOC
    SonOfOC Virgin Detailer
    +1 on D151 and DG501
  19. BoostedMk6
    BoostedMk6 Jedi Nuba
    I use PoliSeal on a orange pad which will clean up the paint nice and remove marring and minor swirls.
  20. Upper Class Detailing
