what in wax makes it haze after application?
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by DetailAddict, Apr 14, 2009.
  1. DetailAddict
    DetailAddict Two Bucket System Washer
    Just curious... what turns wax into haze after application/dry?
  2. slanguage
    my guess would be the evaporatioin of solvents in the wax. like i said, it's a guess.
  3. togwt
    Correct- it is the solvents used in the carrier system that have not ompleatly outgassed
    As a wax ‘sets-up’, it goes through a number of stages.
    1.The first stage is the application of the liquid product; friction will cleanse the dirt, oxidize ation, old waxes etc. In effect you are lifting the dirt away from the paintwork and into the liquid wax and then into the applicator.
    2.The next stage is that you leave the wax to haze. This is where the solvents and oils out gas (evaporate) and leave the resin and fillers behind to dry and set-up on the paint.
    3.Next you remove the excess. Anything that is now not bonded to the paint will be wiped away with the buffing towel and as you wipe away you will end up giving the resin a slight buff to bring out its gloss
    4.A good technique is to buff the wax with a 100% cotton micro fibre cloth and then spritz the paintwork with very cold distilled water and wipe down, this helps to set the wax and will add that little extra gloss. Allow the solvents to vaporize (outgas) in the sun’s heat and then buff to a gloss.
  4. DetailAddict
    what are some of the typical solvents and oil use in wax? so the solvents help dissolve the oil? I would imagine it's hard for the oil to vaporize along in it's original form.
    thanks for the chemistry talk! :)
  5. Chas
    Chas DB Forum Supporter
    never would have thought that about cold distilled water, definitely trying that on the truck when I wax it tonight.
  6. dschia
    dschia Jedi Nuba
    Let us know how is it for you. Want to know will it worth the extra effort..:thumb:
  7. detaildoc
    detaildoc Guest
    Definitely worth it. I just tried this after applying RBOE and it made a world of difference. It removed the hazing left behind (where two different QDs did not) and added gloss. My only question is, is it better to spray the distilled water immediately after removal or hours later after the wax has cured?
  8. togwt
    For more information see article “Carnauba Wax” in the Detailing School section
  9. DetailAddict
    cool, thanks! :)
