Washing WW towel
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by dtaildood, May 12, 2009.
  1. dtaildood
    dtaildood Any Rag Vehicle Washer
    How do you guys wash your waffle weave towels? I wash them like my MicroFibers...no bleach, regular wash, tumble air dry over and over then hang to dry. Sound about right?
  2. P1et
    Same as my regular MF towels: CG MF wash, works great. Yes, air dry...
  3. 911Fanatic
    Should work fine.
  4. Nica
    Um..this is just me but I've never put my micro fiber towels in my dryer. I always hang them to dry...just me though...but I wash all my micro fiber towels in my washing machine with hot, hot water and Micro Restorer...just me though :shrug:
  5. supercharged
    I dry my MF in a dryer on delicate cycle (low heat), I'm too lazy to hang them air dry.
  6. SpecC
    SpecC Wax on..Wax off
    +1
    haven't had a problem
  7. E-Money
    E-Money Birth of a Detailer
    Do you seperate the WW from the rest of the MF or all together in one load?
  8. P1et
    I seperate my WW towels from my regular MF towels, but I doubt it makes a bit difference. The only reason I do it, is because you're more likely to pick up dirt on a WW since you could have missed a spot washing the car. You don't want that to end up in your nice MFs, when you're wiping down a car after having it waxed or so.
  9. Legacy99
    Legacy99 Wax on..Wax off
    I wash my mf separately from my ww mainly because I don't want any waxes or sealants in my ww. Same goes for my glass ww.
  10. Cooter
    Cooter Guest
    I wash like color ww and mf together the first couple of times just so if the colors run, you really want be able to tell, not that it matters from a performance standpoint. I paid my hard earned money for them and I like taking care of them. I'm sure you guys understand me!
    I also dry them on low heat for about 30 minutes. They usually dry pretty fast.
  11. 911Fanatic
    You should be fine as long as you keep your wax towels seperate from your window towels.
  12. dtaildood
    Yea I keep drying towels seperate from wax/polish towels etc... Low tumble dry no heat!!!!
    I believe the heat will create static! I tumble dry for like 2 20min cycles then hang to finish em off! One day I'll come around to trying out the microfiber restore...see what thats all about!
  13. mrgolfrider
    Besides vinager, is there anything otc that would come close to what micro-restore does?? What is in micro-restore?
  14. Ivan Rajic
    Along with all my m/f towels used on paint (polish, wax) and then air fluff in the dryer.
  15. Stems
    Stems Birth of a Detailer
    I do a regular wash with CG Microfiber, then air dry everything. Since it's summer everything dries fast but once winter comes around...stuff is going to take forever to air dry :waiting:
  16. pektel
    pektel DB Forum Supporter
    I only separate my workhorse mf's from my paint mf's, and separate the paint mf's by color. I also put them in a pail of hot water with microrestore to soak for a couple hours before putting them in the wash. If they are really bad, I suppose you could use an APC to soak them. You'd be amazed how much stuff gets released from those towels before they go in the wash.
    I dry them on low for about 20-25 minutes, then hang them up. If you don't completely dry them in the dryer, you won't get the static.
  17. pektel
    No idea what's in microrestore, but before I used it, I would use either tide free or dreft. no softeners, no perfumes.
  18. odgaard
    odgaard Birth of a Detailer
    i hang dry mine too
