Customer brought over an 04 Infiniti M45 today to get detailed. Just doing a 1-step on it but I'm not sure what combo to go with. Does anyone know how M205 works with a green pad?
Fine with a DA machine but you cannot work it more than 45 seconds per panel. On the rotary M205 for me has never finished down well and hate to say it but infiniti paint (and I assume its black) is tricky a paint to work on. I highly suggest using a diminishing abrasive product like Menzerna 106FA or Powerfinish so you can work it longer and refine it at low speed for a long time to ensure it all finishes down clean without leftover buffer trails.
It's actually a beige color. Sadly, I don't have either of those Menz. products, the only Menz. product I have is Intensive Polish.
M205 should work good . . . . . thank god it's not black. You can always step down the pad if you are worried and use M205/White Pad if you have one to give the vehicle a light cleanup.
How long do you work M205 with uber green and rotary for and what speed usually? 45 seconds is like 3 passes?
I never use M205 on the rotary. Its a non diminishing abrasive, meaning just like M105, it works from beginning to end retaining the same cut. With demising abrasives, over time the abrasives in the polish break down to finer bits until there is nothing left.
Thanks again everyone, I'm about to go start on the car in a few minutes after I finish my morning coffee :headbang: I think I'm going to try the IP/Green Pad combo and the M205/White Pad combo to see which one gives me better results.
My mom has a M35 so im sure its similar in paint/clear coat. When i corrected it i used an Uber green w/ Menzerna SIP and managed about 90-95% correction. I dont know if 205 would be aggressive enough
I also think the IP/green pad will yield good results as a one-step. I don't think 205 alone would be strong enough to get the result you are looking for. As a sidenote I haven't had many problems finishing with 205 once I learned how to use correctly.
Hmmm... the PC w/Menz IP + Uber Green didn't seem to be doing a whole lot so I dropped down to an LCC White, still hasn't done a whole lot. Should I try going for IP + LCC Orange?
