great informative write-up.......may i ask which brands of dressing has your stamp of approval ? I understand it need to be cleaned and prepped properly before i treat the rubber. Can you name a topper you believe to be safe and effective?
Thank you for those kind words- Menzerna Wheel Surface and Tyre Cleaner pH 7.5 or 3M Tyre & Wheel Cleaner -39036 (see also Silicone Dresings) above article
if i understand correctly, the old dressings should be removed using the menzerna, or 3m product. and you are not recommending a new dressing to be applied....is this correct?
nevermind,,,,,i found an article you wrote a couple of years ago,somewhere else and it answered my question....thanks, I appreciate your info ! Im a buyer for your book !
