Tires Dirty/Brown Question
Discussion in 'Car Detailing Product Discussion' started by ////AMG, Jul 5, 2011.
  1. ////AMG
    ////AMG Two Bucket System Washer
    On my brothers car his tires are dirty kind of brown looking. I tried AG Custom Wheel Cleaner about 3-4 times and it helps abit. But I can keep spraying yhe Custom Wheel Cleaner and it will still change colour and take brown/dirt off. I can't get tire shine to last quite some time on his tires even. Like on my Mercedes I can get the Sonus Tire Dressing to last weeks or if I'm lucky a month. But on his car only days. The tires only have like 20000kms on them so not that old and were used for one winter.
    Any help?
  2. dankfanatic
    dankfanatic DB Forum Supporter
    are you scrubbing the tire after each round of CWC?
  3. ////AMG
    Yes, and jet sprayed after.
  4. froboy272
    froboy272 Obsessive Detailer
    Try Chemical Guys Grime Reaper 1:3 - I found that to remove the most dirt when combined with a stiff brush.
  5. Swirlkiller
    Swirlkiller Two Bucket System Washer
    Try cleaning the tires with ARO (Amazing Roll Off) with a brush and let it dry. Then apply a tire restorer that NOT has any silicone in it. That was makes them brown... (also some rubber are act different than others, brands etc.)
  6. minorc
    minorc Two Bucket System Washer
    APC for me with a good horse hair brush, well rinsed after. Dried then dressed with Swissvax pneu. New and old tires, always look great
  7. Deep Gloss Auto Salon
    The UV inhibitors in the rubber compound may be comprimised.
  8. mike aesthetica
    mike aesthetica Jedi Nuba
    If the tires are browning this quickly, its probably their "youthful bloom" caused by the release of the their release agent and the antiozonant meant to protect them over time(otherwise they would degrade mega fast). I would suspect this at least for now because as you said the tires only have 2000KMs on them. Depending on the type of compound the rubber is, a lot of tires will do this thus rendering any water based formulas pretty useless after the first couple weeks(which is still pretty good).
    Mike
  9. KlineS157
    KlineS157 Birth of a Detailer
    I always use Megs APC 4:1 and a stiff brush mixed with some elbow grease. Never had something i wasn't satisfied with yet. If it is the tire, dont they make a black dye, used to hide white walls? Good Luck
  10. ////AMG
    Guess I'll get a good APC
  11. supercharged
    sounds like tires might not get dressed on a regular basis. Try out Gloss It Signature Gloss on those, and apply 3 COATS, 30 minutes apart from each other...
  12. Kaban
    Kaban Welcome to Detailing
    ZEP Purple at 4:1 works fantastic!
  13. Jaymz
    Jaymz Virgin Detailer
    Westy's Bleeche White; the only tire cleaner you'll ever need.
    Jim
  14. P1et
    I used CG's Total Interior Cleaner and it worked miracles on tires.
  15. M3ride.
    M3ride. Wax on..Wax off
    P21S TAW is my fav for tire cleaning.
  16. Kilo6_one
    Kilo6_one DB Forum Supporter
    buy new tires...... start over LOL
  17. Stokdgs
    Stokdgs Detail Master
    I have had great results with Meguiars Super Degreaser. You can see the brown stuff coming off after wetting the tires, and brushing the degreaser on and letting it sit for a bit.
    Sometimes, you have to do it twice, but when the tirebrush stays clean, the rubber is also clean.
    As has been said, a lot of tire dressings have Silicone which is not the best for rubber anyway, and will cause some rubber to turn brown.
    I recently tried Tuf-Shine tire clearcoat dressing and its been great! No silicone, tires and white letters stay the proper color for weeks now. Doesnt need to be replaced at every washing either. No greasy residue on you, your tools, or the tires..
    Good luck with your project !
    Dan F
  18. ////AMG
    Yeah lol that is what my brother wants to do. I'll order some of the products mentioned here and try it out.
  19. Kilo6_one
    what kind of tires are they? You can buy a product called tireblack, tire are actually brown to begin with, the manf. add the black color during production. Sometimes the cheaper brands can loose the coloring by just environmental factors, age etc. That is why Tiredressings with UVA and UVB inhibitors are a must, it helps with prevention of this issue.
    Post up a picture maybe?
  20. ////AMG
    Their Continental's the came with car when purchased brand new. Ill try to get some pics later today.
