The HSV GTO (56k no way!!)
Discussion in 'Show and Shine' started by VooDoo, Jul 3, 2009.
  1. VooDoo
    VooDoo Birth of a Detailer
    Just dropped in from down under (had to see the thread about wetsanding a 09 vette for myself.. lol)
    Thought i'd share my latest project. Its a 2004 HSV GTO (similar to the Pontiac GTO but better spec'ed)
    Some of you might have seen this elsewhere in AU but ill post it here as well for those that missed it
    This is the car.
    Car Model: 2004 HSV GTO Coupe
    Car Make: Holden
    Sprint Circuit: 1.02.90
    Clubman Circuit: xx:xx.xx
    National Circuit: xx:xx.xx
    Sportsman Circuit: xx:xx.xx
    Engine Tuner: NA
    Suspension Tuner: Wholesale Suspension, Penrith Sydney
    Current modifications:
    ENGINE
    408 ci Iron block Stroker
    2.8L twin screw supercharger. Self built from billet
    237/242@114 cam. 607/609 lift
    Mahle Pistons, Eagle Crank and rods
    L76 heads, Isky double springs
    L76 Manifold, Holly 90mm TB
    Yella terra roller rockers
    83lb Injectors
    5L Swirl pot
    2 x 044 Bosch Pumps
    Magnafuel MP-9940-B Regulator
    Custom polished fuel Rails
    1/2" Brainded Fuel lines
    Speedflow Fittings
    Custom polished Twin 3" Exhaust
    2 x 4" Metal Cats
    Difillpo 4-1 Headers, 2" Primary's
    Mafless Tune, Current power 338rwkw (last time i dyno'ed it with the smaller cam and heads, no supercharger)
    Power wanted 1000rwhp
    Textralia Z grip
    Braided Clutch and Bleed lines, Custom linkage
    Ripshift - Race version
    Suspension
    Front:
    DMS 50mm Coilovers. Double adjustable (Seperate bump and rebound)
    Superpro Radius rod bushes, lower control arm bushes.
    Whiteline 32mm HD Swaybar
    Rear:
    Koni Double Adjustable shocks (Seperate bump and rebound)
    1000lb Springs
    4 way Camber kit
    Super Pro Subframe bushes
    Whiteline HD Sway bar
    Brakes
    Front: AP Racing 4 spot 350mm Rotors
    Rear: AP Racing 4 spot 330mm Rotors
    Other
    3.91 Diff gears
    Harrop Sports Cover
    Kryo treaded Stub axles
    Gforce1340 Driveshafts
    BMR Subframe connectors
    Driveshafts and Axles (colour coded)
    Diff
    Suspension
    Goals
    Perfection, the underside needs to be perfect and as good as the engine bay or exterior of the car. The engine bay needs to be CLEAN. That means no spot welds, holes, wires, pipes etc. Just an engine in the middle and everything smoothed, polished, painted or hidden
    How
    Smoothed, sanded and seam welded K Frame's
    Powdercoated K Frames. Paint must be to "exterior" standard.
    Chrome Toe links
    Chrome Brake Lines
    Chrome Brake covers
    Polished/Painted Handbrake assembly (even though its covered by the rear disc)
    Polished Sway bay
    Chrome Link Pins
    Chrome Sway bar Brackets
    Nolathane bushes everywhere
    Powdercoated or Chromed bolt heads
    Brake disc's repainted (centers)
    Calipers repainted
    Polished Diff cover (Harrop)
    Chrome Diff cover brackets
    Polished Fuel swirl tank
    Custom Aluminum Fuel tank
    Braided Fuel lines
    Braided Brake lines
    Chrome fuel line brackets
    Billet Fuel filter
    Powdercoated Driveshafts
    Powercoated hubs
    Chrome Springs (if thats even possible)
    Chromed heat sheilds
    Painted Engine, Gearbox
    Polished bell housing
    Mini Tubs (20x10 rears, 20x8.5" fronts)
    Every seam welded, smoothed and painted
    Every unneeded hole filled
  2. VooDoo
    Polished timing cover (yes i know you cant see it, ILL know its there)
    Billet 8 Rib pulleys (I make these so can sell to anyone that want a set)
    Chromed/Polished Tow links, Link pins, Fuel rails and mounts.
    Thermostat housing, ABS bracket
    Temp Rocker covers ( Making some billet ones)
    Polished custom clutch res
    Polished "Ziggy" OTR
    And lastly
    Polished Belt Tensioner
  3. VooDoo
    Few more
  4. VooDoo
    Progress shots
    Main section of the K frame is smoothed and is off for a chemical bath, etching and 3 stage powdercoating. We are doing a silver as the first coat, 2nd coat is a secret atm and then finally a coat of blue over the top. (see test peices at the bottom of this post)
    I got my coilpack brackets done with this 3 stage proccess with took a while to get right as the colour was hard to match, get the metallic content right and and i wanted a slightly darker blue close to edges with the silver showing through in the open areas. To say the powdercoater went beyond the call of duty is an understatement (DAMN i need to get a decent camera though)
  5. VooDoo
    Got the rebuilt diff back this week (Kaaz, new axles etc)
    Time to clean it up a little
  6. VooDoo
    Another update
    Took the fuel system to bits today. It was covered in heat sheilding (the same stuff thats stuck to the floor near the cat's) and spent a while cleaning it off (ill NEVER use it as heatshields again...eeewww)
    Fuel system had spent over 12mths under the car so was dirty so i cleaned it.
    Fuel Pumps (Left is done, right is stock)
  7. VooDoo
    K Frame returns..
  8. VooDoo
    The collection is growing....
    Done the rear hub's, polished the Twinscrew manifold, polished the Alternator and PS pump etc
  9. VooDoo
    See this black stuff under the car... It comes OFF!! With thinners, Bug and tar remover, degreaser and time!
    And becomes
    Getting there slowly
  10. Darkstar752
    Darkstar752 Horizon Detailing
    Wow. Looks sick :applause:
  11. 911Fanatic
    Wow! Keep us posted.
  12. littlemissGTO
    littlemissGTO Welcome to Detailing
    Talk about some OCD detailing there. Looking forward to finished pictures.
  13. flash gordon
    flash gordon Banned
    :yikes:You my freind are a sick man, one of the Worst cases I've ever seen(OCD)
    I LIKE IT...:giggle:
  14. yukon cornelius
    yukon cornelius Birth of a Detailer
    You're doing a beautiful job. More details on the home-built supercharger.
  15. mrgolfrider
    I can't beleive Tom hasn't posted anything here yet, beautiful car!!
  16. dunncsu
    dunncsu Two Bucket System Washer
    You are going to be the new best friend of many people on this board.
    There are a lot of GTOs here (i have a 06).
    Awesome project BTW i cant wait to see it finished.
  17. Spyral
    Spyral DB Forum Supporter
    I always thought Voodoo was crazy on LS1, this confirms it! Amazing work, I love it!
  18. JazzD
    JazzD Virgin Detailer
    That's absolutely amazing mate!
    All lot of hardwork, sweat and tears must have gone into this project.:applause:
  19. detaildoc
    detaildoc Guest
    Wow! That is sweet! Keep us updated.
  20. kustomizingkid
    kustomizingkid Nuba Guru
    Can't wait to see this.... soemone might trump VXR Marc...
