Team Detail - Adam's & Innovative Detailing vs. 2012 Lambo Aventador
Discussion in 'Show and Shine' started by Adam's Polishes, Apr 6, 2012.
  1. Adam's Polishes
    Adam's Polishes DB Certified Manufacturer
    Dylan@Adams & Dave@Innovative Detailing VS. Pure Italian Beauty!
    This has been a project Dave and I have been looking forward to for awhile, the owner is a regular customer of Innovative detailing, but hadn't had a full prep done on the car... yet. Yesterday was the day.
    As you can see from the before shots the issues are very minimal, this was a job to take good and make it great.
    The process was pretty straight forward, basic exterior cleanup and wash, followed by a paint correction. The PC 7424xp and Flex 3401 were used. Most correction was done with Adam's Fine Machine Polish and Gen4 White pads... a few areas were polished again using a Gray Gen4 Pad and Fine Machine. Paint was EXTREMELY soft and anything more aggressive seemed to mar slightly.
    The entire forward section of the car has been covered with PPF film so those areas, especially around the edges, were sealed with Adam's Quick Sealant.
    The entire car was machine glazed with the new Gen4 red pad and Adam's Brilliant Glaze the topped with Americana Paste wax by hand.
    Interior was spotless, a quick wipe down with a towel was all that was needed, glass was also clean and simply wiped with a dry towel.
    Enough talking... on to the pics.
    BEFORE:
    (from a distance everything looked great)
    Dave started in on the wheels and we then moved to a quick wash:
    Documenting some of the problem areas including bird dropping stains, very fine swirling, and some buffing/haze artifacts left behind either by dealer prep or the factory:
    The biggest eye sore was the rear deck... either a previous detailer had hazed the panel, perhaps at the dealer, or the factory prep was a little rushed. Either way the paint was definitely in need of attention:
    Before masking off the film and trim we used the blaster sidekick to eliminate as much of the trapped water as we could. With so many edges and tight areas this car held a ton of water
    Engine bay was spotless. A quick detail spray wipe down for dust was all that was needed
    All masked up and ready to start
    We split the car up and went tow work with the machines
    Checking my progress on some sections... flawless!
    Vertical doors make for some interesting polishing postions
    After we were satisfied with the correction we moved into glazing... gen4 red pad, flex 3401 at low speed, brilliant glaze.
    Icing on the cake
    Black mirror
    This detail approved by Innovative Detailing
    Interior got a quick towel wipe down. Aside from a small amount of dust the interior was flawless. As you can see the dash is a bit of reach...
    Touched up the glass over the engine with Adam's Glass Cleaner and a glass towel
    Tires, trim, and all the vents/diffusers, etc were treated with Adam's Super VRT and/or Adam's In & Out Spray
    Wrapping up... the wind had picked up and we wanted to make sure the car stayed perfect. We had the owner quickly pull the car out for full sun inspection and got it back into the garage to avoid any dust settling on the newly perfected finish
    Out into the sun
    Tucked back in the garage... job done!
  2. Gale Force
    Gale Force Obsessive Detailer
    Pure sex. :applause:
  3. P1et
    It indeed looked pretty damn good in the befores, but you guys have it that extra special "touch". Great work. Tough car to photograph...
  4. cptzippy
    cptzippy Jedi Nuba
    Very mean looking machine. Great work gents.
  5. Bunky
    Bunky DB Forum Supporter
    That must have been exciting and fun. Looks perfect !
    Did you use a pressure washer? When he is rinsing off the foam (foamed with cannon or gun?), I see an interesting looking trigger operated hose end sprayer.
  6. Adam's Polishes
    Thanks for the compliments everyone. Definitely learned a lot on this one... a car with this many lines certainly provides some challenges when it comes to correction that I had never run into before.
    Yes. Dave works mobile so we were working off his trailer. No foam gun or lance... just good old buckets and grit guards. Honestly the wash was more a formality than anything else. It was barely dusty when we got there.
  7. detailersdomain
    great work guys!
  8. ///M LifeStyle
    ///M LifeStyle Birth of a Detailer
    car is beautiful in black!
  9. drew935
    drew935 Auto Salon Works
    Awesome work guys!
  10. Danny
    Danny Nuba Guru
    Man that is pure sex on wheels as it is and now that it is corrected its even better great work guys:thumb:
  11. rwisejr
    rwisejr DB Forum Supporter
    Great job guy's that one hot number.
  12. SRT8Spartan
    SRT8Spartan DB Forum Supporter
    incredible. the lines on this car are crazy.
  13. 911Fanatic
    If that doesn't put a wow in your stick, better check for a pulse.
  14. GoFast908Z
    GoFast908Z DB Pro Supporter
    Excellent work. That Lambo is just gorgeous.
  15. nyrep1
    nyrep1 Obsessive Detailer
    i love that car ....everytime i see one all i can think about is a stealth f117 and a f22 raptor
  16. Mr. Hyde
    Mr. Hyde Any Rag Vehicle Washer
    Cleaned up really nice. Good looking car but I don't like how the front wheels have such a large gap in the wheel wells. I think that would bother me if I owned it..
  17. Dust2Glory
    Dust2Glory Nuba Guru
    The front end can be raised and lowerd for clearance issuea
  18. Adam's Polishes
    Yep. As Dust2Glory pointed out... the front end can life (2" I believe) to clear curbs and other chin spoiler destroying obstacles. Also came in really handy for cleaning the inner fenders... the owners driveway was pretty steep at the end with a rolled curb, even with the nose all the way up he was less than 1/2" from scraping each time he pulled it out.
    Heres some more pics from Dave @ Innovative - enjoy!
  19. Mr. Hyde
    Neato, didn't think about that. Guess lambo thought of everything didn't they.
  20. premshine09
    premshine09 Jedi Nuba
    Awesome work!! Have yet to see one in real life yet but the lines and styling are so radical....the way a Lambo should be :)
