1. Cooter
    Cooter Guest
    Hey Guys,
    Would someone mind explaining the steel wool uses to me and the different grades of steel wool. Also, where you use the steel wool the most, and what grade you use.
    I cant really remember this being talked about very often.
    Happy Detailing,
    Heath
  2. Gemini13
    Gemini13 Obsessive Detailer
    It grades out like this from finest to most abrasive:
    0000
    000
    00
    3
    4
    I found the best selection of it at Ace hardware as they have more of the finer stuff. At HD, Lowes and Menards the only stocked as fine as 00. It can be used on exhaust and glass. Uncoated rim barrels as well.
  3. Denzil
    Heh, I gotta pick up some steel wool. What grade is preferable for exhaust tips and glass?
  4. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    0000 is the one you want to use on glass and exhaust tips.
  5. Cooter
    Cooter Guest
    Thanks D, thanks AR!!
  6. DJBAILEY
    DJBAILEY Birth of a Detailer
    The 0000 wool is also good for 'exfoliating' the outer surface of tired looking plastic trim.
  7. Cooter
    Cooter Guest
    Can it be used on scratched plastic?
  8. slanguage
    good question cooter. my parents grand am has some nasty exhaust tips and was curious about steel wool as well.
  9. eyezack87
    eyezack87 Guest
    Time for a trip to Ace :)
  10. Brian N
    Brian N Jedi Nuba
    Good solid info in this thread thanks very much.
  11. BlueZero
    BlueZero Birth of a Detailer
    My Menards stocks 0000. If your having trouble finding it you could also try a paint store.
  12. DJBAILEY
    I should have said textured plastic. As long as you don't use too much pressure you won't rub the textured bumps off. For smooth plastic I use an AIO to clean those up.
  13. slanguage
    what would be the process on using it for exhaust tips? and should I follow it up with some never-dull?
  14. yukonon22
    yukonon22 Wax on..Wax off
    On Glass? do you use a polish with it?
  15. cleandean
    cleandean Any Rag Vehicle Washer
    When I first started out detailing, I would spend quite a bit of time trying to clean up the plastic entry sills and the plastic rail covers on the bottom of seats. These areas are typically scuffed by the soles of shoes, and on most daily drivers you will find some pretty nasty marks that can be a pain to remove using just an APC and elbow grease. Harsh chemicals like acetone and mineral spirits I soon found out can quickly discolor these areas, and could lead to a costly mistake. I finally found an easy solution to this problem, when I sprayed a piece of 0000 steel wool with a diluted APC and lightly rubbed the scuffs on the sills. This removes the scuffs almost effortlessly, and will not damage the plastic providing you use care and not rub too hard.
    I always carry 2 rolls of 00 and 0000 steel wool on my truck, and pretty much use it on every detail especially when polishing neglected metals.
    I personally like 0000 steel wool and Klasse AIO on badly stained glass. Leaves a nice coat of protection on the glass also.
  16. Asphalt Rocket
    I use with the polish, then wipe clean and go back over with just polish.
    When I use it on the glass I spray glass cleaner than use the steel wool, wipe off and re-clean with just glass cleaner.
  17. Cooter
    Cooter Guest
    Thanks for the tips Dean.
    I like the video btw. Really nice. Very informative.
  18. slanguage
    AsphaultRocket, what metal polish do you use?
  19. Asphalt Rocket
    I just use mothers or Adams.
