Anyone tried salt eraser foam spray? The DIY vinegar and water seems to work ok but leaves vinegar smell. Any other DIY remedies - woolite?
Foam cannon, pressure washer and some soap . When the car is disgusting and covered in salt ill pre-soak it with a round of Meg's hyper wash, let it sit for 5-10 minutes then use my pressure washer to rinse followed by another foam coating of cg's mr. Pink then proceed to washing.Works well and no swirls!! I also add a third rinse bucket if it has a day worth of salt ill just pre soak with mr.pink, rinse then hit it again followed by my normal wash routine.
