Researching Products
Discussion in 'Car Detailing Product Discussion' started by togwt, Mar 17, 2010.
  1. togwt
    Research
    Research others opinions and products, test them and then make an objective decision based upon factual information not marketing hype or brand loyalty. I have always thought that the more facts and information you have at hand the easier it is to judge what information you are being given. After all, how can you fully understand and properly use any product unless you have all the facts? In the final analysis; it’s your vehicle, your hard earned money and your choice.
    Improperly used chemicals can cause damage to the person using them and to surface they are applied to (sometimes irreparably) because the detailer was not educated regarding the chemical make-up of the products they used.
    Car care chemicals are the most misunderstood component auto detailing, they should work on their real merits, not ‘smoke and mirrors'. Proceed with this in mind; the products you use constitute a very small factor in the equation.
    When it comes to product marketing and technical specifications, it is also important to realize that all companies must keep secure their proprietary information and agreements. Without this, no business would have the incentive to develop new products, expand their market, stay competitive, and ultimately - exist.
    Product research
    Material data sheets (MSDS) - is required under the OSHA Hazard Communication Standard. The MSDS is a detailed informational document prepared by the manufacturer or importer of a hazardous chemical. It describes the physical and chemical properties of the product. MSDS’s contain useful information such as flash point, toxicity, procedures for spills and leaks, and storage guidelines.
    Information included in a Material Safety Data Sheet aids in the selection of safe products, helps you understand the potential health and physical hazards of a chemical and describes how to respond effectively to exposure situations. Although there is an effort currently underway to standardize MSDS’s the quality of individual MSDS’s vary. A MSDS may be useful but it cannot substitute for prudent practices and comprehensive risk management.
    An MSDS should be available for every chemical you use. Read these and follow the recommendations for safe use and disposal of the material. The target audience for information in a MSDS is the occupation worker who may be exposed to chemicals at work. However, much of the information is also relevant to consumers.
    Read the manufacturers application instructions and then obtain and read the MSDS sheet to ascertain the chemicals used. Although it should be said that an MSDS is a document that contains details of the hazards associated with a particular chemical and provides information regarding its safe use. The MSDS is required to state the chemical's risks, safety and impact on the environment.
    An MSDS is a fact sheet developed by manufacturers describing the chemical properties of a product. Material Safety Data Sheets include brand-specific information such as physical data (solid, liquid, colour, melting point, flash point, etc.), health effects, first aid, reactivity, storage, handling, disposal, personal protection and spill/leak procedures.
    How to Read a Material Safety Data Sheet (MSDS) How to Read a Material Safety Data Sheet | CMHC
    Chemical Information (MSDS) A-Z- http://[U]www.ehso.com/msds.php[/U]
    Definitions of Terms Used in Material Safety Data Sheets (MSDS) - Definition of Terms Used in Material Safety Data Sheets (MSDS's)
    Chemical Abstracts Service (CAS)
    Each CAS registry number (often referred to as CAS #) is a unique numeric identifier that designates only one substance; it has no specific chemical significance, but is a link to a wealth of information about a specific chemical substance. Since CAS Registry Numbers are not dependent upon any system of chemical nomenclature, they can provide a reliable common link between the various nomenclatures terms used to describe substances. And serve as an international resource for chemical substance identifiers used by scientists, industry, and regulatory bodies
    An extract from one of a series of unbiased Detailing Technical Papers, a library of educational materials that has become the #1 reference for car care on the Internet
    © TOGWT ™ Ltd Copyright 2002-2010, all rights reserved
  2. pushtiulk
    pushtiulk Guest
    great post as always
