Removing pinstripe?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by dpattanas, Feb 19, 2011.
  1. dpattanas
    dpattanas Virgin Detailer
    Any ideas on how to remove painted pinstriping from a car?
  2. tfish1
    tfish1 Birth of a Detailer
    theres a 3m pinstripe removal kit also a heat gun and plastic razorblades
  3. Kaban
    Kaban Welcome to Detailing
    Painted? As in.... it's underneath the clearcoat? I wouldn't mess with that at all if that's the case.
  4. Stokdgs
    Stokdgs Detail Master
    Usually if its a custom pinstripe laid down by a really good automotive artist, its done on top of the paint. And as you already know I am sure, vinyl pinstripes are also applied on top of the clear coat, and are removed by heat, or a solid rubber wheel called a pinstripe eraser that is chucked to an air drill.
    Good luck with this !
    Dan F
  5. Rcrew
    Rcrew Wax on..Wax off
    If you want to do it the long way, work over it with 3M gen purpose adhesive remover and a plastic razor blade...ask me how I know:applause2:
  6. sal329
    sal329 Nuba Guru
    3m pin stripe eraser wheel
  7. nyc_medic
    nyc_medic Two Bucket System Washer
    Does using the 3m pin stripe eraser wheel damage the clear coat?
  8. Kilo6_one
    Kilo6_one DB Forum Supporter
    I have used this to remove pin stripes mouldings etc......... Ive never had issues damaging the clear. But you can burn the paint if you let it sit in one place too long
  9. Shineworks10
    Shineworks10 Virgin Detailer
  10. bryansbestwax
    Easy off works, ken used this method just recently on a drag car.
  11. TheRustySuper
    Are you referring to Easy Off as in the oven cleaner? I would have second thoughts about it if that is the case. In the aircooled VW world the big thing right now is originality--including original paint. So many VW owners have used Easy Off oven cleaner to strip off old repaints to strip the car down to the original paint. I even tried it, Easy off is some nasty, very very strong stuff. Here is a thread showing some of the results of this paint removal.
