I have an unopened bottle of Prima Swirl I had months ago. I've heard it being a strong abrasive and that scared me a bit. Now I might ask a few questions. 1. Is it usable with a rotary polisher? At what speeds and for how long?, 2. How's the cut with it? 3. Does it finish well or do I need another step afterwards? (on VW paint) 4. Which pad is the best for annual scratch/swirl removal? Thanks in advance.
Prima Swirl is on par with Powerfinish. No need to worry about it being strong abrasive, that's not the case depending on what pad you use. Which is the same case with Powerfinish. It finishes down well so you can use it as a one step in most cases. Typically on darker paints it would be ideal to use Amigo after Swirl. It will help add even more gloss and depth to the paint. As for pads LC white would be the one to start out with. If you're not getting the results you want than swap over to LC orange. It's a very nice polish. Prima Cut is the one with strong abrasives. You'll be fine polishing with Swirl.
