ph balanced car soap
Discussion in 'Car Detailing Product Discussion' started by godoman, Oct 7, 2011.
  1. godoman
    godoman Jedi Nuba
    I need ur help with a list of car shampoo's that r ph balanced that will not strip wax and sealants. Looking for ones that r available locally in the US. Want to give my customers a list to choose from so that they can wash their car on their own if they like and still have protection left behind
  2. onebaucom
    onebaucom Birth of a Detailer
    Adam's car shampoo is my favorite. Lots of suds and smells really good.
  3. Chaseme
    Chaseme DB Forum Supporter
    In other words over the counter?
    I can't say there are many mild AND non-gloss enhancing/polymer containing soaps that are OTC.
  4. detailersdomain
    Lusso Auto Bathe
  5. lasthope05
    lasthope05 Jedi Nuba
    Megs gold class and DG901 are top notch soaps that are easily available OTC.
    Personally my favorite is DJ BTMB.
  6. Chaseme
    Never used it but I get a feeling Gold Class is pretty strong. lasthope - do you dilute it down?
  7. godoman
    godoman Jedi Nuba
    Phil is luso avail otc lacally?
  8. lasthope05
    I use the recommended dose of 1oz/gal. How did you get the feeling that its a strong soap? It is a very mild shampoo with good lubricity.
  9. godoman
    godoman Jedi Nuba
    I just read online that the meguiars "nxt generation car soap" is Ph balanced and willbnot compromise the wax
  10. Chaseme
    Just based it off the assumption that most OTC products are strong.
  11. slanguage
    Autoglym is ph neutral and available over the counter.
  12. mike aesthetica
    mike aesthetica Jedi Nuba
    Keep in mind guys that pH completely neutral things sometimes have quite a hard time with traffic film. A pH just just 8 which to me application wise is darn close to neutral will have a better time with oily, grease, dirty stuff - hence why many shampoos are just off that reading of 7 on the pH scale.
    Food for thought.
  13. JSF721
    JSF721 Jedi Nuba
    Best wash for a well sealed, well maintained car is Luso then Ultima Paint Guard Wash then P21S Body work Shampoo. THese are close but I really like the smell of the Luso and re-stocked my stock. I use Poorboys Super Slick and Suds as inexpensive foam washes to loosen up the dirst when the cars are trashed.
    I don't think any of the ones I listed with damage LSP to any great extent although the Luso is probaboy the mildest of the group based on my obervations on my own vehicles.
  14. GTIDamien_407
    GTIDamien_407 Birth of a Detailer
    not sure if it's ph balanced but I use CG MS II works great and it's cheap
  15. Chaseme
    CG MS II is really strong. It leads me to believe it broke down my LSP prematurely.
    But indeed, it is cheap; and it's great for those with hard water.
  16. co78
    co78 DB Forum Supporter
    i like adam's car shampoo and prima hydro wash.
  17. Bunky
    Bunky DB Forum Supporter
    Really? I have never experienced that. I wonder what happened.
    I think Optimum is a good all around choice. Available at many places, works fine even at 0.5 oz per gallon, foams nicely even in a foam gun, smells great, and mid-range cost per wash.
  18. RefPerfection
    RefPerfection Birth of a Detailer
    I'll second that. I used it as a maintenance wash once on my car, and it stripped my 2 coats of Crystal Rock. I'm only going to use it as an aggressive wash soap now, if I ever use it again. If anyone would like to try a sample, feel free to PM me.
  19. hamza7
    hamza7 Welcome to Detailing
    I don't understand why people don't wash with ZEP citrus instead of CG MS II, I mean you want to strip LSP use ZEP, it degreases great, foams great and $9/gallon it's as cheap as water. Unless someone can find me a reason that actually makes a difference. Like the time I heard it dulls trim.
  20. mike aesthetica
    Just goes to show you the difference in prep, sealant/wax with environment, water hardness or softness, and dilutions can go opposite of the spectrum ends.
    Some guys love MS 2 as maintenance wash, other guys are now saying its harsh. Very interesting nonetheless
