New speaker install problem
Discussion in 'Detailing Bliss Lounge' started by zachc, Aug 7, 2010.
  1. zachc
    zachc Two Bucket System Washer
    So if anyone could answer my problem or refer me to a forum thatd be great. I just hooked up 4 cadence 6.5's in my car to a 4 channel hifonics amp. when I turn it on everything works but even with the volume tuned all the way up it isnt loud at all. I know everythings hooked up right, the ground is good, I only used monster cable and rockford wires and cables, and even after turning the gain and HPF up it is still quiet and I cant figure it out.
  2. advs1
    advs1 DB Forum Supporter
  3. Chris@Optimum
    Check the gain adjustment on the amp. Also see if there is a on/off setting for the outputs in the head unit menu.
  4. Keenan T
    Keenan T Any Rag Vehicle Washer
    Also look at your amp to how much power it can hold because if the speakers are going up they will need more power. and if the amp doesn't have the right power capability you will need a new one.
