Nanotechnology -crystalline non-organic polymers
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by togwt, Apr 8, 2010.
  1. togwt
    Every so often a product comes along that changes detailing for the better-Polymer sealents, Detailers clay, Micro fibre, Menzerna abrasives - Silane nano coatings
    Nanotechnology [: the study of the controlling of matter on an atomic and molecular scale. Genrally nanotechnology deals with structures of the size 100 nanometres or smaller in at least one dimension] [1]
    Nanotechnology refers to the study, creation and application of molecular materials with a particle size that is typically less than one nanometre (nm) is one billionth, or 10−9, of a meter. By comparison, typical carbon to carbon bond lengths, or the spacing between these atoms in a molecule, are in the range 0.12–0.15 nm. The significance of a polymer nano-coating is that is can form a very tight bond with the surface of most materials; including glass, paint, plastic, rubber, aluminium, chrome, stainless steel, fabrics, and leather will have surface imperfections i.e. peaks and valleys, micro-fissures when viewed under high magnification. These undulations allow a nano-coating polymer to form a tight molecular bond with the surface it’s applied to.
    1. Nanotechnology polymers form a very tight matrix chain-link structure, which forms both a very strong bond and one that is not easily breached by chemicals or detergents.
    2. This type of polymer coatings with its small particulate size are much smaller than those of water; making them hydrophobic (water resistant)
    3. Due to their size they fill any surface irregularities (micro fissures) which results in a flat surface, one that reflects light without hindrance
    G|Techniq Surface Coatings together with Bayer and BASF has devised a new coating using Silane [: a chemical compound with a chemical formula SiH40] - SiO2 + H2O = SiH40 forming a nano composite quartz polymer lattice Si-O-(R) C1 Crystal Lacquer, a nanotechnology -crystalline composite structure, that provides a highly effective physical UV blocking protection with >98% visible light transmission. Heat exposure; cured films are highly resistant to heat, and can withstand surface temperatures as high as 1,000. 0C. This product contains no silicone oils and only contains reactive resins that cross-link and provide long-term durability. The reactive resins are moisture cured and alcohol is a by product of the reaction with moisture.
    Their P1 nano composite polish that can be applied to paintwork; it uses nano-technology polymers that bond with the paintwork forming a tough, transparent protective coating over the body of a car (or boat or jumbo jet) this ensures a much superior bonding which allows for an incredible water, dust and pollutant repellence and extended coating durability.
    What this means is that you now have a 5-10µ surface coating, which is normal for a nanotechnology sealant, a protective coating of unparalleled durability, the self-cleaning characteristic are important, since the dirt is kept from bonding with the surface (not totally, but to a very high degree), rain is sufficient to wash most of the dirt away, this extends the intervals between car washes, helping to conserve water and car wash concentrate and other cleaners because you need a lot less of them.
    Unlike many coating products on the market nano coatings are an exceptionally thin circa 30 µ (1 Mil) optically clear film. It forms a covalent bond with any molecule that has a hydroxyl group e.g. paint, polymer and vinyl plastic. The surface becomes incredibly water repellent, very easy to maintain, dirt, oil and pollutant repellent and very durable. Applied too thickly it actually crystallises into a very hard rough crust; a demonstration of the nature of the product. G|techniq 3S Smart Surface Science
    An extract from "Polymer - Polymerization", one of a series of unbiased Detailing Technical Papers, a library of educational materials that has become the #1 reference for car care on the Internet
    © TOGWT ™ Ltd Copyright 2002-2010, all rights reserved
