1. dschia
    dschia Jedi Nuba
    I notice there are different thickness in the LC flat pad. Some 1.25 and some 3/4 inch. Any differences between them? Also which is the preferred thickness for rotary and DA..
  2. 911Fanatic
    The foam is the same. The thicker ones have the constant pressure foam backing on them which gives the pad a nicer feel to it. I prefer the thicker ones on either machine.
  3. togwt
    Foam pad thickness
    1.25- inch pad thickness was set as an industry standard because it prevented residues and provided insulation from friction heat from reaching the backing plate, either of which could compromise the Velcro® delaminating backing material. There is a safety margin between the edge of the baking material and the foam with this ‘standard’ foam pad. This foam density provides a protective cushion allowing foam compression to maintain constant surface pressure and it also lessens machine vibration.
    Like all things related to tools, pad thickness comes down to personal preference. I should also state that a 7/8th- inch thickness foam has it backing material flush with the edge of the pad, while the 1.25-inch has a safety margin between the edge of the baking material and the foam, there is also has a cost saving on the 7/8 – inch foam
  4. Bunky
    Bunky Guest
    I had seen a picture of the pad manufacturing process which is simple. They just take sheets of foam and laser/hot wire cut them. There is a lot of scrap in the process so hence the desire to reduce pad thickness. That is, you are paying for the pad plus what gets disposed (recycled?).
  5. agpatel
    LC Manuf:
  6. Denzil
    Wow, thanks for sharing that Ankeet! That's really cool to see that.
  7. Cooter
    Cooter Guest
    Awesome pics Ank!!!!!!!!!!!!! When we buy one pad, we probably pay for that one sheet!!!!
  8. Tim_G
    Tim_G Any Rag Vehicle Washer
    Remembered reading somewhere (neighboring forum) stating not all LC pads are the same, some where tailored to the requirements of the retailers/resellers. Hmm... :shead:
  9. Cooter
    Cooter Guest
    Yeah they do. CMA does. Their gold pads are pretty nice.
  10. crew219
    crew219 Birth of a Detailer
    Hmmm i wonder what a sheet of PFW would look like . . . . would probably make a decent shag rug ;)
