How to repair scratches?
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by lizardloren, Jun 14, 2009.
  1. lizardloren
    lizardloren Virgin Detailer
    Hey everyone, im sure someone has asked this many times before but I can find any. Today I found a nice scratch on the side of my silver jaguar! It is through the clear coat because it failed the fingernail test. I don't want to spend the ridiculous amounts of money to bring it to an automotive body shop. Does anyone have a good guide to fix scratches? I don't trust the general Internet on advice, only detailing bliss!
  2. Spyral
    Spyral DB Forum Supporter
    Well, I had the same problem on my car. I wet sanded it. I am not expert on this, but here is what I did. I taped off the area, got some 2000 grit paper and soaked it in a bucket of water. Then, I soaked the area and went at it. I sanded it lightly with very little pressure until it felt smooth. Once I soaked it down to remove any abrasives and wiped it with a MF it was now full over sanding marks, but I could not feel the scratch anymore. I then hit it with some Adam's swirl and haze remover with the FLEX DA and it removed the sanding marks and the scratch was gone. Now, I did this just from knowledge I gained by reading this forum, I had never wet sanded anything before. It was unnerving, to say the least and I thought I had ruined my car when I saw the sanding results. However, after the polishing process it was amazing. You can't tell the scratch was ever there. If you don't feel comfortable doing this, consult a body shop. Good luck!
  3. lizardloren
    If I sand it would there be any clear coat left? It sounds like you are compromising the paint.
  4. bigpoppa
    bigpoppa Jedi Nuba
    Touch it up, sand it (the blob), and polish it.
  5. Darkstar752
    Darkstar752 Horizon Detailing
    I compound over it and then use a finishing polish, sometimes it makes it goes away, sometimes it makes it significantly better to the point that I'm happy.
    Before:
    After 2x SIP/Orange:
    Done:
    You'll notice that I avoided the part somewhat towards the wheel well, I did this because I would rather have a small scratch than strikethrough.
