ok today i gave in and got foam blaster from home depot Green Earth G-Foam Blaster for 4,000 psi Pressure Washers - AGPWF04 at The Home Depot had to get adapter wand since this uses quick connector Power Care Pressure Washer Wand with Adaptors Set - AP31021 at The Home Depot used pos soap so i didn't expect it to foam good but it still did good job of foaming. i didn't dilute the soap this time it comes with 10oz attachment for solution even though on picture it doesn't seem to be big becouse how small it is comparing to nozzle foaming car should be fun from now on ill update it once i use it with megs shampoo or maxisuds update videos. gun works great, maybe its the soap that i used or maybe its just too close of the range to use it but judge for yourself [video=youtube;EdH6TxNej8Y]http://www.youtube.com/watch?v=EdH6TxNej8Y[/video]
POS = piece of $hit he states that he will use meg's or maxisuds at a later time eluding to his opinion that those are better soaps than the one he put in the cannon for demo...
dont think so. i think farther you are the better. i did see difference once i was going around the car but i think couse it was using last of soap that was there before. yep you are right. on Evo i used mix of maxi suds, CG CWC and some meguairs gold glass but it wasnt mixed in bottle well so they kinda went by stages. i used piece of shit soap when i first time used it but didnt do video of it. soap didnt foam well couse it was i think simonize self drying BS soap
Does the power wand set just plug into the handle of your pressure washer? I will be getting one from my in-laws soon, they upgraded so lucky me for the old one. This looks very do-able as far as cost goes compared to some other options out there.
