Help Me Buy a Foam Cannon *It's Time*
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Handz, Jan 22, 2010.
  1. Handz
    Handz Obsessive Detailer
    So, I just picked up my Karcher 1700 PSI Pressure wahser..... And now its time to buy a foam cannon.
    So, I am looking for an online store to Purchase a foam cannon from. I was going to buy the AutoGeek cannon but maybe you guys can point me in the direction of a better cannon, maybe at a better price. :worship2:
    :popcorn:
  2. slanguage
  3. GDAL
    GDAL Guest
  4. slanguage
    i dont know what adapter you will need. You could ask JL. i think he has a karcher. i have a gas PW :D
  5. MINIz guy
    MINIz guy Two Bucket System Washer
  6. supercharged
    I got mine from polishedbliss.co.uk
  7. edwinbong
    edwinbong DB Forum Supporter
    would like to know as well!
  8. dankfanatic
    dankfanatic Guest
    +1 on the one from polished bliss. Hit me up Greg if you wanna try it out.
  9. bryansbestwax
    autogeek has them as well with different fittings, not sure if they are the same quality as the UK ones
  10. togwt
    A wide range of adaptors are available to fit most pressure washers on the market. Simply match the adaptor to the coupling on your pressure washer. Foam cannon are built to work with virtually any pressure washer. It includes the brass male nipple connector to connect the foam gun with the desired pressure washer fitting.
    You also get your choice of pressure washer fitting; six fittings are available, and you can buy extras if you ever buy a different pressure washer- Car Wash Shampoo, Microfiber Towels, Chamois & Wash Mitts
    Karcher Parts / spares – Pressure Parts.com Karcher Adapter A
  11. Handz
    whats the difference between the polishedbliss cannon and the PW Mall Cannon?
  12. dankfanatic
    dankfanatic Guest
    prob not much difference.
  13. Tech
    Tech Any Rag Vehicle Washer
  14. Handz
    So, polished bliss is like $90 shipped with a fitting. The pwmall.com cannon is even cheaper but you gotta buy the fitting..... Hmmmmm
