Gloss It Clay?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by - Z -, Aug 1, 2009.
  1. - Z -
    - Z - Virgin Detailer
  2. Aesop
    Aesop Jedi Nuba
    Its worth it. However Gloss Enhancer is a much better used as an enhancing product, such as Z8. I would not waste gloss enhancer on claying.
  3. - Z -
  4. Reflect
    I've used FK425 at like 20:1 and it worked fine. I don't see the point in wasting product at 1:1.
  5. Aesop
    Aesop Jedi Nuba
    You corrected, I corrected to match. PS Megs Last Touch can be Diluted 2:1 and its only about $17 for a Gallon.
  6. DJ_JonnyV
    DJ_JonnyV DB Forum Supporter
    I've recently been converted to using an ONR / water mix for clay lube. I used to use Adam's detail spray for lube, but think it left too much behind when moving onto polishing. Nice thing about ONR is that it wipes up extremely easily. Have to give props to MadOzodi for getting me going on this.
  7. SpecC
    SpecC Wax on..Wax off
    20:1 is a huge dilution for that QD! If you don't mind me asking, what's wrong with full strength FK425?
  8. - Z -
    And I believe the recommended dilution for ONR for claying is 64-1, which has to make it #1.
  9. pektel
    pektel DB Forum Supporter
    I also use ONR at clay lube dilution. Works great.
  10. pektel
    Unless I'm using my Bilt Hamber. Then it's just distilled water!
    BH is my favorite clay.
  11. ahwil_lim
    ahwil_lim Wax on..Wax off
    ONR as a clay lube is cheaper ...
  12. Solidsnake
    Solidsnake Jedi Nuba
    That's not bad..
  13. dsms
    dsms DB Forum Supporter
    I have stopped using Megs last touch as lube. It was so slick which was great but it had too much protection in it to come off easy before polishing. Even tape wont stick after using it. I use ONR now and it works fine, just smells sterile!
