foam cannon/lance help????
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by slanguage, Jul 21, 2009.
  1. slanguage
    I just got a used power washer, and wanted to know what fitting(s) and what foam cannon/lance will fit my machine.
    I think the fittings are 1/2" but not sure so I took some pics of the machine and the end of the wand (taken apart) to see if this helps.
    ^^ Wand apart.
    Measured end of wand. looks like 1/2" but not sure.
    Here's a link to some specs on the machine I have, if this helps:
    http://www.ppe-pressure-washer-parts.com/devilbiss-excell-pressure-washer-exwgv2121-parts
    Any help in this matter would be greatly appreciated.
    Thanks,
    -Roger.
  2. PJS
    PJS Birth of a Detailer
    Looks like a standard M22 fit, as per Kranzle machines.
    If the trigger is standard with the machine, and not a replacement, then a quick call/e-mail to the makers Devilbiss will make sure.
  3. rwisejr
    rwisejr DB Forum Supporter
    Defenitely an M22 Kranzle connector according to the manual .
  4. slanguage
    ok. where do I get the M22 franzle connector and the foam cannon/lance?
    also, is there a difference between the cannon and the lance, or is it just a name thing?
  5. rwisejr
  6. budman3
    budman3 Birth of a Detailer
    I just got the AG one with the Kranzle -- fits perfectly on my Craftsman pressure washer; pretty much the same set-up that you have.
