dsms detail - 40hr. Hacked BMW Restoration Detail
Discussion in 'Professional Detailer's Studio' started by dsms, Aug 4, 2010.
  1. dsms
    dsms DB Forum Supporter
    Complete 4 day paintwork restoration on a Monaco Blue BMW 135i.
    Backstory, in bullets:
    -Car was bought with 10k miles on it
    -New owner saw car on dealer lot looking clean and very glossy (glaze fillers)
    -After a few weeks of washing the gloss was lost and real finish revealed
    -Paintwork had very little depth, clarity or wetness and new owner wanted all of the latter brought back to the car
    Some before pictures in sunlight. Car had lots of RIDS, swirls and was covered in machine holograms as the dealer attempted to fix the prior damage and ended up making it worse. Along with that caked up wax and polish residue was left in nearly every crack and crevice.
    If you dislike lots of correction shots and 50/50's this writeup may not be for you. The main focus was the correcting the finish as NO interior work and NO engine detail was carried out on this detail.
    Wheels cleaned using Sonax wheel cleaner applied to the wheel DRY followed by Iron Cut
    Car was beading well due to obvious glaze fillers left over from the dealership, all of which needed to be stripped off 100% before correction. The above sun shots were after the wash stage (no IPA yet)
    - Pressure washed the finish followed by a 5 minute foaming using CG citrus wash
    - Foam rinsed off and the car was sprayed down with Optimum Power Clean at a 5:1 dilution
    - Finally a 2 bucket wash was carried out with a strong mixture of straight Dawn
    Clayed using a riccardo bar with ONR as lubrication in a Kwazar bottle, which is an absolute must for at least your wheel cleaner and clay lube.
    After clay the finished was wiped with straight IPA multiple times until it was squeaky clean.
    Here is the car all prepped and masked after taking the necessary paint readings
    Onto correction. After a bit of time playing around with combinations I decided on a process which yielded me the best result, safely. I began playing with foam pads but that was yielding me only 80-85% correction while generating a lot of heat. I decided wool was need to correct the car properly.
    Process as follows
    M105 on black wool pad (2x)
    Menzerna SIP on DD Yellow Cutting Pad
    Menzerna 106FA on a LC tangerine hydro
    Menzerna PO85rd on a DD Black pad
    All 50/50 and correction shots taken after the first 2 correction steps (no finishing polishes) and straight IPA wipedowns to ensure zero filling
    Hood under the halogens, deep RIDS
    After wool and foam compounding, great difference in clarity without using a lightsource.
    Light compounding with 4" foam around the washers, tape removed after wool so I could clean up the areas tightly around the washers and also remove some of the tape lines left behind after compounding.
    Closeup of defects under Fenix TK40
    Front fender was done entirely with 4" wool and 4" cutting pads as larger pads made for uneven correction on the contours
    Trunk section, some more serious RIDS
    Cleaning up the wool holograms with a DD cutting pad
    50/50 Trunk under halogen
    Closer view
    Wooling out the rear quarter
    Before
    After
    Here is a great example of 2 things, first being general neglect from the original owner and second is heavy machine holograms left by the dealer
    The door... I took a bunch of different shots from all angles with both my SLR and Point and Shoot camera to show all the defects and difference in color before and after correction
    Under LED light
    Before
    After
    3" pad work here, lowered speed on the makita and spent more time making passes to work out the defects
    Before
    After
    Here is a video 50/50 of the passenger door
    YouTube - Street Dreams Detail - BMW 135i Before and After Paint Correction
    The funny thing about hacks is, and luckily for me, they are not extremely thorough when buffing out cars.
    Notice how the rear bumper has substatially less defect and holograms compared to all the major panels? This is more realistic of how much defect you would find on a car with about 10k miles on it
    Before
    After
    And back to a bit more hack'age but still not terrible
    Tailight before
    Finishing down with 85rd after 105
    After
    50/50 on drivers door into rear quarter, few RIDS I was unable to remove
    Before
    During
    After
    Only very light marring in this strip between the kidney grill and headlight, knocked out in 2 steps with only little compounding needed, no wool
    50/50 on front bumper
    Once all the compounding with wool and foam was finished I gave the car one more IPA wipedown and moved onto the finishing stages, here is the 135 out in sunlight after finishing down to check my work.
    Remember this...
    This..
    To this..
    Car was finished with 2 layers of Menzerna Powerlock, wheels treated with Rejex sealant for protection.
    Finished car at 7pm. Finished shots
    The owner came to pickup and was beyond ecstatic with the result, I had kept him updated with correction shots through the process and when he finally came I went over the whole car with him using the LED light.
    Remember that door before?
    In total after I added up all my hours spent on each day this detail came out to about 39hrs, a bit over my original estimate of 30-32.
    The owner wanted his new BMW to look like a proper Monaco Blue BMW should and after talking with him for a very long time before even starting the job I knew how much he was looking forward to the end result. Its great to have enthustastic people who really care about the work that was put in. He asked for a lot of pictures and as you can see from the above writeup... I kindly obliged :picture:
    Thanks for looking.
  2. Road Trash
    Road Trash Birth of a Detailer
    A job well done. As always.
  3. P1et
    Stellar work, looking a HEAP better in the afters.
    When buying a used car, and thinking the finish is in "OK" shape, how is one to really make sure what the paint looks like underneath all the glaze and fillers? Just do an IPA wipe down on the forecourt?
  4. vtec92civic
    vtec92civic Nuba Guru
    wow. car looks great man. Talk about hacked up in the beginning. That BMW was horrible! So sonax is strong enough to tackle BMW brake dust?
    I see in the background that you have a huge stock pile of pads LoL. Always great work though and camera skillz Dave. Gloss was brought back for sure and then some.
  5. maxepr1
    maxepr1 Jedi Nuba
    Nice work Dave! Nice to have customers who really understand all the work that goes into perfection!
  6. supercharged
    David, you trully are doing some AMAZING paint corrections out there! Dude, the car looks sooooooo goooooood it's kinda hard to describe!!! And knowing the hardness of BMW clear coat (I have 2 BMWs), I know how hard it is to get there.
    I still have a lot to learn from you!
  7. Chas
    Chas DB Forum Supporter
    Amazing work as always Dave, that thing was hammered and like you said is now a true Monaco Blue, great job man.
  8. Carn
    Carn Welcome to Detailing
    Top shelf effort as always Dave. I can only imagine how pleased the owner must have been when seeing his NEW car :thumb:
    Not sure if I missed it but what black wool pad did you use?
  9. JoeyZ
    JoeyZ Obsessive Detailer
    Great job dave. that blue looks spectacular.
  10. Pats300zx
    Amazing work as always Dave....
  11. vtec92civic
    i would also like to know Dave what black wool pad that is.
  12. kei169
    kei169 Wax on..Wax off
    looking great!
  13. Auto Concierge
    "Crisp supercleaness" again.
  14. 911Fanatic
    Fantastic work Dave.:awesome: I almost cried at the close ups of the RIDS.
  15. Max405
    Max405 DB Forum Supporter
    Dave,
    You are a magician. Thanks for sharing.
    Joe D
  16. Denzil
    Great work Dave!
  17. Denzil
    Great work Dave!
    This is my guess but I want to say it's a TufBuf wool pad. The TufBuf wool pads are by far my favorite wool pads to use.
  18. P1et
    Hey Dave, was this an $11,000 detail?
    OH MATE I JUST HAD TO!!!
  19. luke093
    luke093 Welcome to Detailing
    Nope, he one-up'ed the guy. This one was $15,000!
    Lol!
  20. Emile
    Emile Welcome to Detailing
    Very nice work. It's sad to see that the advancements in glazes these days are mostly utilized to fool prospective automotive buyers.
    Amazing turn around nonetheless.
