Divine Detail - 2008 Infinity G35xS
Discussion in 'Show and Shine' started by Nica, Jun 23, 2008.
  1. Nica
    Well a co-worker of mine just purchased this vehicle and unfortunately someone or something scratched the passenger side quite bad, you’ll see what I mean shortly. Well the vehicle was in for a full exterior paint correction, the vehicle:
    2008 Infinity G35xS
    The owner was kind enough to wash the vehicle prior to dropping it off :applause2:
    Well the vehicle:
    As you can see the vehicle ‘looks’ to be in good shape or is it?
    Well first up P21S Total Auto Wash is applied to the wheel wells:
    Then P21S Gel is applied on the rims:
    ARO is applied to the tires, now it was time to agitate the wheel wells. This was done with the Black ShMITT:
    Next, it was time to agitate the inside of the rims, for this the two inch wool brush is used:
    For the face of the rims a Swissvax brush is used:
    Now to give the tires a good scrub, for this Meg’s tire brush is used:
    This is how all that scrubbing looked like at the end:
    All that’s left to do is rinse it all off:
    This process is done to all wheel wells, rims and tires.
    Next, it was time to connect the CR System:
    With the help of Deionized water it was time to wash the vehicle off, I first gave the entire vehicle a good rinse to inspect if there was any kind of protection on the vehicle. To my surprise, the vehicle had no protection what’s so ever :what:. So no need to go with the P21S Total Auto Wash shampoo, so this time I went with Zymol Clear with the Zymol Sponge and the two bucket method:
    During the washing process the door shuts were also taken care of, first P21S Total Auto Wash is applied:
    (sorry for the blurry picture :sorry:)
    Then with a Swissvax brush the door shuts were agitated and wiped of with a yellow micro fiber towel.
    Well on to claying the vehicle, as always the clay of choice is Riccardo clay bar. Here is the clay bar before:
    Here is the clay bar after:
    The vehicle had a bit of tar on the lower panels so all lower panels were sprayed off with Tarminator.
    The vehicle was once again rinsed off and first with the help of my air compressor water was removed any water that remained on the vehicle was removed with a waffle weaved micro fiber towel it was dried off.
    I started this detail a bit late, so this is as far as I was going to go on the first day. The rims, washing, tar removing and claying the vehicle took a whapping 5hrs :confused:
    Well that concludes day one.
    Day two:
    First up the paint was inspected, now looks like I’ve been having quite a few vehicles that have been difficult to capture the defects and this one was no exception but I did manage to capture the scratch that my co-worker wanted me to remove:
    Well I inspected the scratch and it really wasn’t that bad, it was just going to require some time to correct, lots of time :shrug:.
    Next up it was time to tape up the vehicle:
    With the help of the PosiTector 6000 paint gauge readings were taken:
    Now the readings of this vehicle were something else :shead:, the vehicle was all over the place. From as high as 120 microns to as low as 72 microns the graph shows it better:
    Next up all plastic trims were measured with the help of my PosiTector 200:
    The readings on the plastic trims were quite healthy:
    Well I’m now ready to start the paint correction process, a section is taped up and let the fun begin.
    First combo was:
    Menzerna 85RD3.02, 3M UK Black pad, Metabo at 1500 RPM with 3M UK Backing Plate.
    This combo gave reasonable results but Menzerna was acting up, not only was Menzerna acting up but the clear coat on this vehicle was hard and for the first time ever I was up against the sticky clear coat :wall: Boy this sticky clear coat is quite a pain to work with, I mean I barely even got two to three passes with the Menzerna combo mentioned above and the foam pad was gumming up, skipping and worse part it was causing my Metabo to over heat and shutting down. I thought that maybe a alcohol wipe down would help but it didn’t, this sticky clear coat issue is quite brutal…actually I made a video of it, as I’ve always been curious about this sticky clear coat issue many UK detailers have experience and finally I have to work on :cheerl::
    http://www.detailingbliss.com/downloads/desktops/Sticky Clear Coat.m2t.wmv
    (Again sorry for the slow down load time, but I insist in quality :nod:)
    Well this sticky clear coat made the paint correction very, very difficult :wall:.
    Well here we go, here are the results of the Menznerna combo mentioned above.
    Before:
    After:
    As you can see it made a bit of a difference but there were still many swirls/random deep scratches left over. Not to mention the sticky clear coat was making it extremely difficult to polish with Menzerna.
    Well Menzerna was just not going to cut it and after trying all the polish products in my arsenal I settled on 3M UK.
    First up 3M UK Fast Cut Plus, Sonus SFX-2 Polishing Pad (White), Metabo at 1500 RPM with 3M UK Backing Plate.
    This combo was still acting up, gumming the pad up and over heating the Metabo but it gave very good results:
    Due to the gumming up and the polish reacting to the sticky clear coat I gave the section a final pass with the following combo:
    3M UK Ultrafina SE, Sonus SFX-3 Finishing Pad (Blue) Metabo at 1500 RPM with 3M UK Backing Plate.
    This brought back the gloss to the surface and removed all holograms being left from the Fast Cut Plus and its miss behaving. The best part is that Ultrafina SE was not acting up at all, it performed extremely well, the only draw back was that it was a real pain to buff off all polish residue again do to the sticky clear coat :doh:
    Here are the results with this combo:
    Well there you have it, this sticky clear coat still has a resolution and this proved to be the combo to do the entire vehicle:
    Here is how the entire trunk finished off:
    Now remember I mentioned I tried all my products I have in my detailing arsenal well, I tried using all the other polishes I have in my collection, Optimum, Scholls and 3M US and nothing was working, all polishes were acting up and causing the Metabo to over heat, pads to skip, polish to gum up. I also tried each product with different foam pads, 3M UK, 3M US, Menzerna, Meg’s, Skolls pads and nothing was working, the pads that gave the best results were the Sonus (older version) pads. So this sticky clear coat issues is something else, I’ve never had an experience as this.
    So the correction process was very pain full and quite long, here are some process pictures.
    Before:
    After:
    Tail lights were also corrected with the same process as the paint.
    Well I was making my way around the vehicle and finally made my way to the long scratch and here is a 50/50 picture of how it finished off:
    I was very pleased with these results :cheerl:
    Here is a 50/50 of the hood:
    Well like I said a very long paint correction process due to the sticky clear coat not to mention the entire vehicle was covered in polish dust:
    All dust was removed with Zymol duster:
    Now it was time to give the entire vehicle a final wipe down with alcohol mix and various micro fiber towels.
    I was running out of time now as I looked at my cell phone and realized it was close to midnight so after the final wipe down I applied a healthy coat of DG#105 to the rims:
    Making sure to get inside the rims as well.
    Well seeing as it was midnight now I decided to call it a day, it was a long paint correction process a total of 14hrs was spend during the paint correction process all due to the sticky clear coat :shakehead:
    Third day:
    Well the final day was quite fast as all I need to do is apply the LSP to the vehicle.
    Now seeing as this vehicle belongs to a co-worker of mine I figured I’d use something from my own personal collection…now what to use..:shead:
    Well first up I applied Zymol HD-cleanse Professional:
    Wiped off with many Cookie Monsters.
    Now for the wax of choice:
    I haven’t used Zymol Glasur for a bit so thought I’d use it.
    I do enjoy the hand application process :cheerl::
    Glasur was left on the vehicle to bond. During that bonding time the exhaust tips were taken care off.
    The weapon of choice is my favorite:
    Here is how the exhaust tips finished off.
    Before:
    After:
    Before:
    After:
    Now it was time to buff off Glasur, for this Cookie Monsters were once again used:
    All tires were dressed with Zymol Tyre. DG#105 is also buffed off. Now the vehicle was left to sit and after five hours, a final Field Glaze wipe down is done and here are the end results:
    Oh remember that long scratch:
    Well here is the end result:
    After that frustrating paint correction, I’m happy to say that the scratch was completely removed and my co-worker was thrilled to see the end results :thumb:
    I just love the lovely curves on this vehicle :druling:
    Here is a walk around video:
    Well that concludes this detail, it was a very long detail and I thought it was going to be an easy one, well I’m glad to say that this vehicle was fun to detail, frustrating but I enjoyed the challenge. This sticky clear coat is something else, it was a good challenge and I look forward on doing more Infinity vehicles specially 08 models to compare if the sticky clear coat is like that for all 08 models.
    Like always feed back (good or bad) is always appreciated.
  2. er1k
    er1k Obsessive Detailer
    Car looks great Nica! Good job on those scratches!
  3. richy
    Carlos..I've been so curious about how it would be to do the paint on one of these Infi's. I get quite a bit of work from my Infi dealer, so it's just a matter of time until I get one to do. In fact, when their guys screw up, it's me to the rescue. I can't imagine they'll do well if they try one..we'll see. Thanks very, very much for taking the time to do the video. Did you think of trying a foamed wool pad? That was really strange to see the chunks come flying off!!!:gross:
  4. Strs90
    Strs90 Birth of a Detailer
    I don't post much here.. but Very Nice job.. as always.:worship2:
    I wonder if a stiffer urethane backing pad would make it better or worse or have any effect in this situation?
    I was thinking the polish just doesn't have enough lubrication but the foamed wool suggestion sounds like a good idea!
  5. Nica
    Thank you for the feed back and yes I was very happy with the removal of the scratch, it turned out great...it was a bit of work but perfection takes time and I was more then willing to put in the time :thumb:
    Oh man richy this one was a tough detail, I enjoyed every minute of it but boy this sticky clear coat is something else. I haven't tried the foam wool pads, come to think of it I don't think I have any of them in my detailing arsenal but I did try the Menzerna wool pads and even they were acting up...the polish would stick to the wool pad and chunks would fly off just like in the video. It was really strange, that's why I stuck with the Sonus pads and the 3M UK products. I was very surprised to find that the 3M US version performed worse then the 3M UK polish...well I'm expecint two more 08 Infinitys, I can't wait for them as it will be nice to compare and see if I have the same situation with them.
    Oh and if you do an 08 Infinity model I look forward to see it and read your experiance with it.
    Glad you found the video helpfull bro :chest:
  6. detaildoc
    detaildoc Guest
    Incredible work Carlos! :worship2:
  7. pirex
    pirex DB Certified Dealer
    VERY nice work Carlos! The results was nice, no more scratch ;) Glasur always looks nice on silver and gray cars!
  8. sneek
    sneek Nuba Guru
    looks good. A challenging detail always feels good, and sometimes puts you in your place. I have actaully never seen a G35xS on the road before...I didnt even know they existed, great work!
  9. Denzil
    Thanks for sharing this special vehicle Carlos. I'm sure one of those cars with sticky clear coats will come my way as well in the future. Until then, I'll breathe easy, haha.
  10. sly
    sly Birth of a Detailer
    Great work as always!!!:worship2: Thanks for sharing and video sticky gumm paint:thumb:
    Nica, where did you get woolies brush. cant find it in website
  11. bigpoppa
    bigpoppa Jedi Nuba
    Man that polishing looked absolutely miserable in the video. Have you considered using a PC for a job like this? Although, I'm not too sure that it would be *that* much better on the paint than the rotary.
    BTW, I find the Meg's tire brush is much more ergonomic/confortable when you take the handle off and hold it by it's head when you scrub the tires. Just a suggestion.
    Oh yeah, the car looks great. :)
  12. P1et
    So nice Nica, it's always amazing that when you see the before pictures and it looks good, to then see the afters and look twice as good!
  13. Deep Gloss Auto Salon
    Looks like you had your work cut out for you on this one.... glad you were finally able to show the CC who is boss and get it to acceptable levels...
  14. Dust2Glory
    Dust2Glory Nuba Guru
    do u think maybe adding some sort of oil, or like some clearkote glaze would of helped the polish from drying out as fast??? or maybe preping the pad with some sort of QD?
  15. DLR Detailing
    DLR Detailing Jedi Nuba
    Wow, that was a long one! Your extra effort shows! :applause2: I really enjoy reading your posts and documentation of your details. Very nice pictures!
    Thanks for taking the time to share! :thumb:
    Dave
  16. FMINUS
    FMINUS DB Pro Supporter
    Hey Carlos, how much Glasur do u use when u apply by hand? It looks like u used 1/4 of the jar!
    knowing you, you prob did! LOL
  17. Nica
    Thank you doc :peace:
    Thank you my Norway brotha, I agree Glasur is very nice on silver/gray colour vehicles :worship2:
    You said it sneek, nothing like a good challenge to test the detailing skills :thumb: These vehicles are gorgeous, inside and out...I really like the front of this vehicle as it has wicked curves...kinda reminds me of a Porche...kinda :giggle:
    Oh there vehicles are fun to detail, challenging but remember what dosen't kill you only makes you stronger :cheerl:
    Glad you enjoyed the write up and videos...as for the wool brushes, these things are extremely rare, if you ever find them jump on them. I was fortunet enough to get my hands on two sets of these brushes and that was all I could order, they wouldn't let me order the dozen of each I wanted. Any who, due to a patent (like the Riccardo issue) these wool brushes can't be manufactured :shrug: shame because these brushes work extremely well.
    PC, no...there is no way I'm ever going back to the PC, the vibration is extremely bad and don't want nothing to do with a PC..dont' get me wrong it the tool that got me started but that only lasted for a month...I also have the Flex DA but even that I find vibrates too much for my taste. As for the Meg's tire brush, I personaly prefer it with the handle because I always hit my knucles on the floor and that's why I prefer the handle but it really is personal preference :shrug:
    Thank you P1et, glad you enjoyed the detail :peace:
    Thank ou Deep Gloss, I had fun with this vehicle....but I'm fortunet to be able to take my time with these details as I honestly dont know how I would do it if I had a limited time. Respect to those that detail so fast :worship:
    Um..not sure to be honest as for the glaze, well see (this is just my opinion) but by adding a glaze there is a chance of just filling the imperfections but like I said that's just me, I could be out to lunch on this so I stay away from products that have fillers. As for preping the pad with QD, I didn't use this method on this vehicle but I have used it in the past and I din't really like it. I know prime my pads with the polish and it has performed well...well till this vehicle came along that is :shrug:
    Thank you DLR very much appreciated my friend, as for the pictures. I drilled my co-worker prior to this detail and finally I was able to capture the difference I was making...still took me a bit of time and many pictures to capture the difference I was making but only a few turned out...but better some then none right :peace:
  18. Nica
    lol..I actually didn't use that much. I've been using Glasur for a bit as I like the glow it leave the vehicles with so this is a used container...but I'm sure I wasted a bit of it hahahahaha. I love applying it nice and thick :cheerl: Besides I have two more tubs of Glasur in my collection :giggle:
  19. JLs Detailing
    Great job as usual Nica. I think Glasur is one of Zymol's most underrated waxes. I was blown away by how it performed when I used it. Man do these clients of yours know how much I like to see your interior details, LOL. They should consider my feelings when booking a detail with you, LOL!
  20. Nica
    Thank you JL :thumb:...as for Glasur oh yes, I agree. Glasur is one of those waxes that takes you by surprise, I enjoy using it...heck who am I kidding I enjoy using all waxes specially hand application ones :cheerl: As for the interior, oh I wish I could have detailed the interior as it wasent to my standart..:thumbdown:..ooh it still had the plastic covers on the GPS screen and on some of the wood trims panels too...but I have a feeling this vehicle will be back as I edumacated my fellow co-worker on how to properly care for his new pride and joy...ooh I can have fun in this interior too :thumb:
    Next vehicle I get when they request only an exterior I'll tell them that I have a friend that insists on me doing the interior :shrug: I don't think they would mind lol.
