Subject: Lincoln MKX Requirements: Clean up and prep for Opticoat Exterior - Wheels were prepped with Sonax Wheel Cleaner and cleaned up with various brushes - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down - Wheel wells were cleaned up - Washed with Adam's Car Wash - Decon - Wash down and rinsed - Door jambs were cleaned up - Nano Scrub AutoScrub - Dried - Tires dressed - Masking - Paint Measurement - Menzerna FG400 - MF Cutting Pad - Sonax 3/6 Nano Polish - Uber Green Pad - Opti Coat - Inspection with Fenix, 3m Sun Gun, Infratech, and natural sunlight - Wheel wells were cleaned and dressed - Rubber and Plastics Treated - Exterior windows and mirrors cleaned and sealed - Exhaust tips cleaned - Windows were autoscrubed, cleaned, and sealed Products used Links to products used - Auto Finesse Lather Auto Finesse Citrus Wolf's Decon Gel Sonax Full Effect Wheel Cleaner NanoSkin AutoScrub System Auto Finesse Rejuvenate Opti Coat Wolf's Glass Guard Auto Finesse Satin Tire Dressing Optimum Metal Polish Engine Optimum Power Clean Adam's In and Out Tools used Uber Wool Wash Mitt Uber No Name MF Towels Rupes Bigfoot LHR15ES Uber Buffing Pads Defelsko Paint Meter Fenix TK35 Brinkmann Kranzle Pressure Washer Cam Spray Foam Canon 2 Grit Guard Buckets with Caddies Uber Firehose Nozzle Metro Air Force Blaster Before Presoaking the trim with AF Citrus AF Citrus was used on wheel wells and tires Wheel wells cleaned up Wheels were hit with Sonax Full Effect Wheel Cleaner and Wheel Woolies Wolf's Decon Gel Using the Uber Detail Brush to hit up the gas cap, jambs, etc Foam Wash with an Uber Wool Wash Mitt Rinse Customer requested debadging Before After Engine After Rupes Bigfoot and Auto Finesse Rejuvenate on an Uber Green Pad Auto Finesse Rejuvenate was used on the chrome trim as well. After
Nice work Phil! A couple of questions...... Did you apply opti-coat over af rejuvenate? :shead: Also, at what step did you use the wolf's decon gel? After pre-soak and rinse? After wash with wash mitt?
we did the decon gel and the citrus during the prep cycle. decon on the paint, citrus on the wheel wells, tires, etc. we sprayed it down and then washed it. rejuvenate was used as a pre cleaner prior to the opti coat.
