Detailed: 997 Porsche Carrera 4S revival
Discussion in 'Show and Shine' started by Misha, Sep 11, 2010.
  1. Misha
    Misha Nuba Guru
    This 72k mile daily driver, was clearly showing it's use, as expected. Definitely not abused, however, it needed some revival. We spent quite a bit of time restoring this beauty to factory like condition. The wheels came off, the top was treated, the mufflers were polished in the wheel wells, as well as the control arms and a-arms and so on! The leather was brought back to it's delicious tan color and the paint looking fresh. The pics do a lot of the talking here, so check it out!
    Products used:
    Meguairs M105 + purple wool pad
    Meguairs M105 + yellow pad
    Menzerna 203 + orange pad
    Menzerna 106 + white pad
    Menzerna 106 + black pad
    Meguairs M38 trim dressing
    Meguairs Wheel Brightener
    Meguairs Super Degreaser
    Meguairs Last Touch
    Meguairs APC
    Mink oil leather conditioner
    P21S Paint cleanser
    P21S TAW
    P21S Polishing soap
    Stoners Tarminator
    3M Adhesive remover
    CG Citruswash Clear
    CG Wheel cleaner
    CG Diablo Wheel gel
    #000 steel wool
    Plexus clear bra cleaner
    RAGGTOPP Fabric Protectant
    RAGGTOPP Fabric/Vinyl Cleaner
    Sonus green ultrafine clay
    CG Maxisuds clay solution
    Collonite 476 (for rims)
    Wolfgang Fuzion wax
    Sprayway ammonia free window cleaner
    Rejex
    Might be other products
    Procedure: We took care of the convertible top by first spraying with Raggtop cleaner, agitating with swissvax brushes and then rinsing. The car was pre-rinsed, soaked with TAW and left to dwell for a couple minutes while misting to keep from drying. Afterward the car was rinsed off, washed with citrus based car soap and lambs wool mitts. Once rinsed, vehicle was clayed, good amount of contamination on it. Car was then dried and all water was blown out. Convertible top was sprayed with fabric protectant and removed per instructions on the product. After it top dried with air, it was covered up and taped off. Car was moved to polishing area, put on jack stands and all wheels were removed for cleaning. Wheels were cleaned then sprayed with Tarminator to remove all tar, then cleaned more. The final cleaning with wheel cleaner removed all previously used chemicals, then dried and waxed with collonite wax for protection. Exhaust tips were cleaned. While the wheels were being cleaned, wheel wells were cleaned and dressed; control arms and exhaust tanks were polished; calipers cleaned and sealed with Rejex. The wheels were put back on, the car was lowered and wheels were taped off to prevent dusting during polishing stage. At this point, the car was ready for polishing but first, the interior needed to be cleaned. The leather was cleaned with Meguairs APC solution and then conditioned with Mink Oil. The interior and floor mats were vacuumed. We tried several polishing combinations on several panels and used what worked best. Plastic panels were polished with wool pad and M105, then Menzerna 203 and then Menzerna 106. Final stage of polishing was done in 2 steps. Menzerna 106 with white pad until polish broke down then switched to black pad to finish polishing for maximum results. Some were done with yellow instead of wool because the paint was softer and not as damaged. Menzerna 203 and 106 was used on the car as the medium and final polish. After all of the polishing was done, the clear bra was polished/cleaned with plexus product then wiped down with alcohol mix and polished with Menzerna 106 and a green pad. This made huge improvement on clarity of clear bra. The tail lights were polished with the same products as rest of the car. Car was then paint cleansed and waxed with Wolfgang Fuzion wax. We let the wax cure for half hour before rinsing the car off with water and drying. The front and rear engine compartments were dressed and all of the jambs and glass were cleaned.
    Onto the pictures.
    Couple before pics
    Convertible top treatment
    Clay bar after a panel
    Interior before, after and 50/50
    Taillights before/ after [​IMG]
    Wheels before/after
    After waxing
    Wheel wells
    Exhaust tips
    Front and Rear engine compartments before/after
    Clear bra cleaning/polishing 50/50
    Correction pictures: before/after and 50/50
    Reflection/Final pictures
  2. dsms
    dsms DB Forum Supporter
    Great work, that was really neglected, some outstanding 50;50s!
  3. Brynjar
    Brynjar Birth of a Detailer
    Awesome 50/50's... I know that this paint is not easy to work with, so thumbs up for the result.. Looks very nice:)
  4. CG SoCal
    CG SoCal Any Rag Vehicle Washer
    Nice recovery on a fairly well hammered Porsche. Hope you talked they guy into maintaining the car with porper washes and polishing when needed.
    Again, nice save.
  5. 911Fanatic
    Great save! That thing was in baaaaad shape.
  6. BrendanS
    BrendanS Welcome to Detailing
    Great job! You do some great work and it definitely shows. The wheels turned out great.
  7. Nice Work :applause:
  8. swest0223
    swest0223 Any Rag Vehicle Washer
    Amazing work! Just curious, is Porsche paint considered hard or soft?
  9. mato
    mato Any Rag Vehicle Washer
    Wow... Fantastic Job!!!
    How many hours did you have on that thing?
    What did the owner say when he saw it?
  10. supercharged
    amazing work, Misha! That's a lot of paint correction!!!
  11. Misha
    Misha Nuba Guru
    this paint was pretty soft, new Porsches have harder paint (soft comparing to new Cayman paint)
    over 2 days it took us 32 hours or so
    he was amazed, we sent him long email with progress pics and only response we got was "WOW", we gona get his weekend car to detail, i guess he was please with results
  12. Max405
    Max405 DB Forum Supporter
    Misha,
    On the befores, I couldnt even figure out what color the car was. The afters leave no doubt.
    Its amazing the some people treat even the most desireable cars like an appliance. You turned it back into what it should be.
    Great Job!
    Awesome.
    Joe D.
  13. Misha
    Misha Nuba Guru
    its Daily driver car, we found auto car wash receipts in car while we were cleaning it so no wonder it was in that condition. at least his weekend car in little better shape, as far as i seen out on sun sun but then again porshe didnt look half as bed on sun then under lights
  14. Misha
    Misha Nuba Guru
    fixed and added more pics
  15. XFS
    XFS Guest
    Nice job!! :mounty: resculine!!! hehehehe
