Detailed: 2009 BMW M5 Carbon Black Metalic
Discussion in 'Show and Shine' started by Misha, Oct 30, 2010.
  1. Misha
    Misha Nuba Guru
    A 2009 BMW M5, in need of a full corrective detail and paint touch up, due to a garage door spring snapping and sending wheels off track and across the hood of this sub 10k mile beauty. Ove the course of 3 days we built up touch up paint and let it cure, sanded smooth and cleared over top and moved onto correcting the paint. In the mean time the engine bay had been fully cleaned and treated, the wheels sealed with THREE applications of Poor Boys Wheel Sealant and detailed the inteior. With all coffee stains removed, and wheels protected, we made sure the rest of this subtle, yet commanding vehicle was flawless in every aspect. The pictures do a lot of the talking here, enjoy!
    Products used
    Chemical Guys Citrus wash
    P21S TAW
    P21S polishing soap
    Optimum Metal polish
    Chemical Guys wheel cleaner
    Meguairs M105 on purple wool pad with PC
    Menzerna SIP on orange pad with PC
    Menzerna 106 + white foam pad on PC
    IPA 30%
    Sonus Ultrafine green clay
    CG maxi suds mix as clay lube
    Menzerna FMJ
    Poorboys Wheel sealant
    Meguiars Super Degreaser
    Poorboys natural look
    Sonus Ultrafine Green clay with Maxi suds solution as lube
    Process: car was rinsed and sprayed with TAW twice, rinsed again and washed. Clayed and washed again, wheels were cleaned and whole car was air dried first and then remaining water wiped with drying towels. After car was taped off and touch up was done on couple spots on hood per customer request. Did test panel on trunk and it had to be compounded first with M105 and PFW pad, paint readings ranged from 98 to 144. Whole car except for roof was done with this combo, roof only needed yellow pad and M105. After that stage, usual follow up with white pad and Menz 106 did not work left too many defects left by compounding so car was done with SIP and orange pad. After it was polished with Menz 106 and white pad. After car was wiped down with IPA mix and sealed with Menzerna FMJ, left on for 20 min and wiped off, next afternoon second coat of sealant was applied, car was cleaned inside and leather was treated with Mink oil, vacuumed. Over corse of 3 days wheels were sealed with 3 coats of Poorboys Wheel sealant. Car was rinsed and dried, tires dressed with Poorboys Bold and bright, windows cleaned.
    As car arrived:
    Paint condition
    Wheels before and after (wheels look like they been somewhat clean outside)
    Exhaust tips exhaust tips before and after (polished with mothers powerball mini and optimum metal polish)
    Engine bay was cleaned as well
    Correction pictures
    hood
    doors
    There was a long scratch on hood
    Before
    Wetsanded
    After
    Interior before and after
    After/reflection pics
    Final pics
  2. cnut
    cnut Guest
    Great results especially considering you used a da. Just goes to show that technique has alot to do with good results and not just the machine. Good work!
  3. Misha
    Misha Nuba Guru
    thanks, consider this, all this was done with PC7424 (not xp version). we gona order 2 griots garage buffers, it will make life much easier, we had 7424xp but dont have it anymore
    This car came in for in dire need of freshen up. Car belonged to a farmer who probably didn’t care about it much. Car looks like it was not washed in years, there was dirt everywhere.
    Car prep:
    Products used
    Zep purple 4:1 (tire degreaser)
    Meguiars Superdegreaser (all purpose degreaser)
    Chemical guys wheel cleaner
    Zep Citrus degreaser 10:1 (paint degreaser/wax remover)
    Chemical Guys Citrus wash Clear (car shampoo for removing wax and contamination)
    Clay Magic Medium clay (very aggressive)
    Chemical Guys MaxiSuds/water mix (clay solution)
    Headlights reconditioning:
    1000 grit sand paper
    2500 grit sand paper
    Meguairs M105 + purple foam wool pad on PC
    Menzerna 203 + orange pad on PC
    Paint correction / protection
    Meguiars M105 (compound) + purple foam wool pad Rotary/PC
    Meguiars M205 (medium/final polish)+ green pad
    IPA 30% (final wipedown after polishing)
    Collinite 845
    Collinite 915
    Other
    CG VRT dressing (trim dressing)
    Poorboys Natural look (interior trim dressing)
    Poorboys Bold n Bright (tire dressing)
    First what we did when car came in was wetsanded the headlights because they original clear coat was peeling. After that all jambs were cleaned, rubber trim around doors were taken off and cleaned. Outside trim was degreased. After that car was washed, finish was so bad that it was hard to drag wash mit on the paint, after wash car was clayed, washed again, there was huge difference after claying the car, there was a lot of contamination. After drying car it was taped off and tried couple combinations and realized that one step customer asked for will not works well. So we decided to do 2 step, after one step paint still had a lot of scratches due to improper washes. But it did finish a lot more glossier and more reflective. Whole car was compounded and followed up with Megs M205. After polishing car was wiped down with alcohol and sealed with Collinite 845, left on for couple of hours and then wiped off, 24 hours after it was waxed with collinite 915 to protect car even further as customer asked, this should yield 6-12 month of protection. Tape was removed and outside trim was dressed
    Car prep:
    Trim around windows degreased
    All body seams cleaned Before/After
    [​IMG] [​IMG]
    Paint reconditioning
    Overall condition of the paint
    Before/After
    Before
    After
    Trunk
    50/50
    After polishing
    Door handles were very scratched up
    Before
    after
    Headlights wetsanded, polished and sealed
    Trim dressed
    center grill dressed, sides are not
    Finished pictures
  4. stingray23
    stingray23 Jedi Nuba
    great job
  5. Camaro5Ryan
    Camaro5Ryan Any Rag Vehicle Washer
    Nice work!
    Sent from my iPhone using Tapatalk
  6. supercharged
    Your work is very impressive, Misha! Well done!
  7. Socal Brian
    Misha,
    You always do top quality work and I like your writeups too. You get such great results with just the PC and the customers are lucky you go so easy on their paint. What brand pads do you like to use with the PC ? Does Sonus still sell the green clay? I only see white on their website.
  8. Misha
    Misha Nuba Guru
    i got 3 bars long time ago and we on last bar. i see ppl sell it here now and then, probably gona try different clay
    we use 5.5" uber and 4" LC pads
  9. supercharged
    I remember Sonus green clay @ $5 a bar. That's when I stocked up...I got 20 bars at that time...now I have less...
  10. detaildoc
    detaildoc Guest
    Looks great man, nice 50/50's.
  11. detailersdomain
