Detailed: 2002 Porsche 911 Turbo - DD resto
Discussion in 'Show and Shine' started by Misha, Jul 3, 2010.
  1. Misha
    Misha Nuba Guru
    This daily driven, Seal Grey 996 911 Turbo, with 60k miles was corrected by us at Good Vibes Autosport. While a daily driven, considerably milled car, it was in rather decent shape. Definitely many swirls and defects on the vehicle, however definitely kept in great shape being a garaged vehicle. The car was conditioned all around, as the pics will speak for themselves!
    Products used
    Meguiar’s M105 and yellow pad (some place wool was needed)
    Menzerna 203 and green pad
    Menzerna 106 and white pad
    Jetseal109 and blue pad
    Wolfgang Fuzion wax
    Meguairs Superdegreaser
    P21S TAW
    P21S Polishing soap
    P21S Finish restorer
    CG wheel cleaner
    Rejex
    Before pictures of paint
    Paint correction needed Meguiar’s M105 on yellow pad because of deep scratches, spoiler and rear bumper needed purple wool pad. After this car was followed with Menzerna 203 in some areas and in some with Menzerna 106. Paint was cleansed from polishing oils with P21S paint cleanser, then sealed with Jetseal109 and left to cure for 20 minutes, then removed and allowed to cure for another 20 min per instructions, Fuzion wax was applied and removed.
    50/50 paint correction pictures after Meguair’s M105 and yellow foam pad
    Wheels were cleaned with CG wheel cleaner, tires cleaned with Meguiar’s Superdegreaser. Tires were dressed and wheel sealed with Rejex
    Wheels before/after
    Headlights were wetsanded with 1500 and 2000 grit sand paper, polished with Meguiar’s 105, Menzerna 203 and 106 and sealed with Blackfire Wet Diamond
    Tail lights polished with Meguiar’s 105, then with Menzerna 203 and followed up with Menzerna 106
    Exhaust tips were cleaned with P21S polishing soap and polished with P21S finish restorer, sealed with Rejex
    Before/After
    Reflection/final pictures
    Thanks for reading!
    Oakes
  2. billyblooshoes
    Looks great misha and oakes team. Did you guys go rotary or DA on this one?
  3. 02blackout
    02blackout DB Forum Supporter
    Great work! Love the before and afters!
  4. Max405
    Max405 DB Forum Supporter
    M,
    GREAT job! You worked magic. Now all that car needs is to loose the turbo twisties and put on some 997 turbo wheels.
    Outstanding job! Thanks Mikael!
    Joe D
  5. Misha
    Misha Nuba Guru
    DA only, we very rarely use rotary (usually for Ceramic clears)
