Detailed: 2000 Jetta TDI revival
Discussion in 'Show and Shine' started by Misha, Nov 8, 2010.
  1. Misha
    Misha Nuba Guru
    This 2000 Volkswagen Jetta came to us as a recent purchase in a heavily neglected state. We were asked to give it a solid thorough cleaning and help bring the paint back a little. Full correction was not asked for or even expected. We gave it a full turnaround and really got the vehicle grime free with the paint brought back to life and fully protected for the winter. The pictures will truly show the differences made.
    Car prep:
    Products used
    Zep purple 4:1 (tire degreaser)
    Meguiars Super degreaser (all purpose degreaser)
    Chemical guys wheel cleaner
    Zep Citrus degreaser 10:1 (paint degreaser/wax remover)
    Chemical Guys Citrus wash Clear (car shampoo for removing wax and contamination)
    Clay Magic Medium clay (very aggressive)
    Chemical Guys Maxi Suds/water mix (clay solution)
    Headlights reconditioning:
    1000 grit sand paper
    2500 grit sand paper
    Meguiars M105 + purple foam wool pad on PC
    Menzerna 203 + orange pad on PC
    Paint correction / protection
    Meguiars M105 (compound) + purple foam wool pad Rotary/PC
    Meguiars M205 (medium/final polish)+ green pad
    IPA 30% (final wipe down after polishing)
    Collinite 845
    Collinite 915
    Other
    CG VRT dressing (trim dressing)
    Poorboys Natural look (interior trim dressing)
    Poorboys Bold n Bright (tire dressing)
    First what we did when car came in was wet sanded the headlights because they original clear coat was peeling. After that all jambs were cleaned, rubber trim around doors were taken off and cleaned. Outside trim was degreased. After that car was washed, finish was so bad that it was hard to drag wash mit on the paint, after wash car was clayed, washed again, there was huge difference after claying the car; there was a lot of contamination. After drying car it was taped off and tried couple combinations and realized that one step customer asked for will not works well. So we decided to do 2 steps, after one step paint still had a lot of scratches due to improper washes. But it did finish a lot glossier and more reflective. Whole car was compounded and followed up with Megs M205. After polishing car was wiped down with alcohol and sealed with Collinite 845, left on for couple of hours and then wiped off, 24 hours after it was waxed with Collinite 915 to protect car even further as customer asked, this should yield 6-12 month of protection. Tape was removed and outside trim was dressed
    Car prep:
    Trim around windows degreased
    All body seams cleaned Before/After
    [​IMG] [​IMG]
    Paint reconditioning
    Overall condition of the paint
    Before/After
    Before
    After
    Trunk
    50/50
    After polishing
    Headlights wet sanded, polished and sealed
    Trim dressed
    center grill dressed, sides are not
    Finished pictures
  2. TheRustySuper
    Looks great! And I think someone has said this before...what's with all these poor neglected Jettas all of a sudden?
  3. blacK20
    blacK20 Birth of a Detailer
    Wow look at those headlights! How could he even see anything at night.
  4. Misha
    Misha Nuba Guru
    Headlights were ok just clearcoat started to peel off so I wetsanded clear completely off middle pic is wetsanded, not how it was when we got it if that's what u think :)
  5. Domman56
    Domman56 Birth of a Detailer
    beautiiiful turnaround Question how do you like that dressing it looks like it works great
  6. Misha
    Misha Nuba Guru
    it looks great but like others doesnt last very long, couple weeks tops with good weather
  7. Socal Brian
    Another fantastic job Misha! I'm sure the customer was very pleased.
  8. supercharged
    Very nice work, man! I see you have quite a collection of products there.
  9. luke093
    luke093 Welcome to Detailing
    Whats the easiest way to remove the white lithium grease... my dad went nuts on hinges "to keep them rust free." He did a very messy job and APC just didnt cut it, as much pressure was needed and it wasnt the making the paint on hinges looking nice... Honda soft clear!
  10. slanguage
    that car was disgustingly filthy. looks nice and clean now.
  11. kakeuter
    kakeuter DB Forum Supporter
    Fantastic work! The car turned out great.
    -Kody-
  12. adamturbo
    adamturbo Any Rag Vehicle Washer
    Quality work! Looks much better without the 10 years worth of road grime. ;)
    Ever worried about Zep Purple damaging the rims when cleaning the tires? I have a jug of it sitting in the garage (unopened), not sure if it's safe to use on non-steel parts. I suppose once its diluted it's not too bad.
  13. Misha
    Misha Nuba Guru
    not sure about how to remove it. i think zep should be able to remove it
    i go from Richy advice on using this product and so far no damage observed. dont spray on rims, usualy if you spray on tires it just runs on rim edge and doesnt get on face, scrub it and rise with large amounts of water, works ok for me
