These wheels were part of a full correction and coating on a 2009 Lexus RX350. I wanted to focus on the wheel cleaning, because I actually think this is an overlooked service that consumers should have performed at least once a year. As you will see in the pictures, this was a wheels off detail. This is the first main point of the detail. I feel that pulling the wheels off and deep cleaning them is a great way to keep them looking new for years. Products used: Sonax Full Effect wheel cleaner Various brushes Stoner Tarminator P21S Total Auto Wash Coating: Modesta BC-06 spray application using and airbrush. As you can see, first we must put the vehicle on jack stands or use a dedicated lift to get the wheels off. This image has been resized. Click this bar to view the full image. The original image is sized %1%2. Wheels set at the back of the shop. I did not want to get any cleaner on the vehicle, because at this time the paint correction and coating application had been performed. This image has been resized. Click this bar to view the full image. The original image is sized %1%2. One thing of note is that I keep these wheels cleaned on a regular basis. I use the SpeedMaster brush always to clean the barrels, but as you will see, deep cleaning is still needed. This image has been resized. Click this bar to view the full image. The original image is sized %1%2. Sonax Full Effect starting to work This image has been resized. Click this bar to view the full image. The original image is sized %1%2. Looks like I cut an artery! This image has been resized. Click this bar to view the full image. The original image is sized %1%2. I actually agitated the wheel cleaner at this point to help with the decon. This image has been resized. Click this bar to view the full image. The original image is sized %1%2. Rinsed and tar removed. The textured areas still hold some deep embedded contamination. This image has been resized. Click this bar to view the full image. The original image is sized %1%2. This image has been resized. Click this bar to view the full image. The original image is sized %1%2. Take the time to polish the exterior of the wheels at this time This image has been resized. Click this bar to view the full image. The original image is sized %1%2. Deep clean the tires as well This image has been resized. Click this bar to view the full image. The original image is sized %1%2. At this point the tires are cleaned and un-dressed. Great time to clean the inner wheel wells that you never see. This image has been resized. Click this bar to view the full image. The original image is sized %1%2. Cleaned and dressed This image has been resized. Click this bar to view the full image. The original image is sized %1%2. Final pic on the vehicle after coating This image has been resized. Click this bar to view the full image. The original image is sized %1%2. Now these wheels will stay cleaner longer and when they are cleaned,it will be much faster. Enjoy, HUMP
